Potpourri Panzer disaster
Well the aromatic therapy fluid mixed with the HL aerosol weakened the rubber seal on the piston of the smoke unit causing the fluid to leak out, I seen a puddle of clear oil under tank 21. Its all cleaned up now except for that happy odour, I think further smoke unit fluid experiments should be done on a unit outside a tank !
take the displacement motor and piston out, drill a bigger inlet hole, install a 25mm x 25mm x 10mm fan, the life of your smoke unit will come back with a hush.
