bulldog
Old 06-23-2008, 01:54 PM
  #51
Panther F
Panther F's Avatar
Default RE: bulldog
You should post some pics of your work in your gallery here Rob. You've got some nice stuff!
Old 06-23-2008, 02:24 PM
  #52
fv432
Banned
Default RE: bulldog
Damn fine idea panther f will have to do that
Old 06-23-2008, 04:03 PM
  #53
fv432
Banned
Default RE: bulldog
finished the engine hatch
and made a start on the headlights
tested the fibreoptics with my work light
ID:	977055   Click image for larger version
ID:	977056   Click image for larger version
ID:	977057   Click image for larger version
ID:	977058   Click image for larger version
ID:	977059   Click image for larger version
ID:	977060   Click image for larger version
ID:	977061   Click image for larger version
ID:	977063   Click image for larger version
ID:	977064   Click image for larger version
Old 06-23-2008, 05:51 PM
  #54
hdbeast
hdbeast's Avatar
Default RE: bulldog
Great, know I'm going to need to start working on the dog again[:@] all looks great, nice job fv432, again.
Gary
Old 06-24-2008, 10:39 AM
  #55
fv432
Banned
Default RE: bulldog
sorry gary [][][] LOL
Old 06-26-2008, 06:05 PM
  #56
fv432
Banned
Default RE: bulldog
some more work done
installed the headlights and the frame (still got to finish the frame run out of brass stock[])
made a new drivers lid handle and filled around the gap in the drivers periscopes
knocked up a new pioneers rack from brass and made a start on detailling the tools
cleaned up the spade and cleaned out the hole in the pick axe head
ID:	979156   Click image for larger version
ID:	979157   Click image for larger version
ID:	979158   Click image for larger version
ID:	979159   Click image for larger version
ID:	979160   Click image for larger version
ID:	979161   Click image for larger version
ID:	979162   Click image for larger version
ID:	979164   Click image for larger version
ID:	979165   Click image for larger version
ID:	979166   Click image for larger version
Old 06-26-2008, 06:09 PM
  #57
swathdiver
swathdiver's Avatar
Default RE: bulldog
That pioneer rack is a masterpiece! Instead of sticking it on the tank you could put a ring on it with a 24k gold chain and wear it! Perfect gift for the Mrs! [:-]
Old 06-26-2008, 06:14 PM
  #58
fv432
Banned
Default RE: bulldog
Thanks james Don't give her anymore ideas finally got the honey-do list down don't want another one LOL
Old 07-04-2008, 06:25 PM
  #59
fv432
Banned
Default RE: bulldog
now the front end is complete made a start on detailing the turret
first to go are the nasty plastic grab handles
next was to re-site the MG placement
then for the tricky fiddly bit the four holes are for the smaller tie-downs (not sure if I'm gonna regret this bit[][]) and are 0.3mm dia[X(][X(]
ID:	984111   Click image for larger version
ID:	984112   Click image for larger version
ID:	984113   Click image for larger version
ID:	984114   Click image for larger version
ID:	984115   Click image for larger version
ID:	984116   Click image for larger version
ID:	984117   Click image for larger version
ID:	984119   Click image for larger version
ID:	984120   Click image for larger version
Old 07-06-2008, 05:38 PM
  #60
fv432
Banned
Default RE: bulldog
update on the build
more pics showing the "tie-downs" made from staples
and mudguard supports scratched from .005" brass sheet
ID:	985071   Click image for larger version
ID:	985072   Click image for larger version
ID:	985073   Click image for larger version
ID:	985074   Click image for larger version
ID:	985075   Click image for larger version
Old 07-06-2008, 05:49 PM
  #61
fv432
Banned
Default RE: bulldog
a little detail added to the loaders hatch and periscope shield also the rear stowage box get's some detail
ID:	985096   Click image for larger version
ID:	985097   Click image for larger version
ID:	985098   Click image for larger version
Old 07-10-2008, 05:53 AM
  #62
fv432
Banned
Default RE: bulldog
pioneer rack completed with working hinge so the spade is removable (just incase the bulldog gets stuck in the mud)
started making the tool holders for the turret
ID:	987279   Click image for larger version
ID:	987280   Click image for larger version
ID:	987281   Click image for larger version
ID:	987282   Click image for larger version
ID:	987283   Click image for larger version
ID:	987284   Click image for larger version
ID:	987285   Click image for larger version
Old 07-10-2008, 07:17 AM
  #63
971wright
Default RE: bulldog
Hi Rob very nice job look forward to a closer inspection at Bovington
best regards pete
Old 07-10-2008, 05:18 PM
  #64
fv432
Banned
Default RE: bulldog
thanks for that pete
yep the bulldog will be at bovvie and the T34 with a couple of m26's
hoping to get the tiger moving for then as well
Regards rob
Old 07-11-2008, 12:53 AM
  #65
jom
jom's Avatar
Default RE: bulldog
I drove past Waiouru army museum today so stopped and took some pictures of the stripped out NZ Bulldog that sits outside. And yes that is snow on the ground, and yes the sun went in and the wind started to howl as soon as I climbed up onto it....
Jo
ID:	988130   Click image for larger version
ID:	988131   Click image for larger version
ID:	988132   Click image for larger version
ID:	988133   Click image for larger version
ID:	988134   Click image for larger version
Old 07-11-2008, 12:59 AM
  #66
swathdiver
swathdiver's Avatar
Default RE: bulldog
Yours looks better Jom!
Rob, that's some incredible detail work! Wish I was half as talented!
  #67
jom
jom's Avatar
Default RE: bulldog
More
ID:	988136   Click image for larger version
ID:	988137   Click image for larger version
ID:	988138   Click image for larger version
ID:	988139   Click image for larger version
ID:	988140   Click image for larger version
ID:	988141   Click image for larger version
ID:	988142   Click image for larger version
Old 07-11-2008, 01:07 AM
  #68
jom
jom's Avatar
Default RE: bulldog
and still more....
ID:	988145   Click image for larger version
ID:	988146   Click image for larger version
ID:	988147   Click image for larger version
ID:	988148   Click image for larger version
ID:	988149   Click image for larger version
ID:	988150   Click image for larger version
ID:	988151   Click image for larger version
Old 07-11-2008, 01:34 AM
  #69
jom
jom's Avatar
Default RE: bulldog
Here are some photos that Malcolm Thomas sent me (see his new book on NZ armour "Royal New Zealand Armoured Corps Kiwi Armour 6" ISBN: 9780958235044 - covers 1960 to present day, Bulldog, Scorpion plus armoured cars etc.) showing the MRDEC camouflaged Bulldog on manoeuvres.
Jo
ID:	988156   Click image for larger version
ID:	988157   Click image for larger version
ID:	988158   Click image for larger version
ID:	988159   Click image for larger version
Old 07-11-2008, 03:22 AM
  #70
fv432
Banned
Default RE: bulldog
wow jom those pics are fantastic [X(][X(][X(]
many thanks for your time and trouble to put those together it's very much appreciated
hope i can do the N.Z dog justice with my attempt[][]
thanks james really just playing around with some brass and new ideas It is fun though
Kind regards Rob
Old 07-11-2008, 04:01 PM
  #71
fv432
Banned
Default RE: bulldog
some more work couldn't resist this one it's been screaming at me since i bought the dog[X(][X(]
might have to do a sideline in building hinges LOL
ID:	988541   Click image for larger version
ID:	988542   Click image for larger version
ID:	988543   Click image for larger version
Old 07-12-2008, 04:22 PM
  #72
fv432
Banned
Default RE: bulldog
started work on the lid
found the original just wasn't up to scratch so decided to re-make out of brass sheet
got the cross formed now need to form the side angles to make the lip and fabricate and install the hinges
Regards rob
ID:	989244   Click image for larger version
ID:	989245   Click image for larger version
ID:	989246   Click image for larger version
Old 07-12-2008, 05:39 PM
  #73
fv432
Banned
Default RE: bulldog
the lid finished awaiting the hinges and finishing
ID:	989287   Click image for larger version
ID:	989288   Click image for larger version
ID:	989289   Click image for larger version
ID:	989290   Click image for larger version
ID:	989291   Click image for larger version
Old 07-12-2008, 09:22 PM
  #74
wackywheelz
wackywheelz's Avatar
Default RE: bulldog
It's official, you are crazy!!
Old 07-12-2008, 10:36 PM
  #75
blitzkrieg65
blitzkrieg65's Avatar
Default RE: bulldog
Rob that is really nice work, and you are definately sparking some ideas! I can see you making almost the whole tank out of brass..[sm=75_75.gif][sm=idea.gif][sm=shades_smile.gif]
You and the British Bulldog will have to team up or is this tank just for show!?
The Blitz
