Sprocket Problem
Old 06-25-2007 | 03:07 PM
Default Sprocket Problem
hi there guys
I have a problem with my front sprocket on my HL Tiger, the prob is the screw that tightens the sprocket to the tank wont tighten at all? the screw appears to be okay so would the prob be the metal piece that is on the tank? does anybody have any ideas on how I might be able to solve this? maybe a longer screw?
as always, thanks for the help guys
Jeremy
Old 06-25-2007 | 03:55 PM
Wozwasnt's Avatar
Default RE: Sprocket Problem
Sounds like the thread has gone on the drive shaft. You could try a longer screw or a slightly bigger screw or you could try putting some glue down the hole.
Old 06-25-2007 | 04:06 PM
maybe a medium threadlock? thanks for the tip my friend
