Alternative to Gearbox run in method?
Hi all,
I was wondering if anyone had heard of or tried to run in their gearboxes using any of those "Teflon" oil treatment products (such as PTFE "Slick 50" brand).
I haven't tried it myself but I reckon the process should work at this scale just as well. Just imagine, a quiet gearbox, almost friction free, and long lasting. It should also work on the bearings. Once the surfaces have been treated you could almost run them "Dry" without oil.
I wonder if it's worth trying. Unfortunately I only have plastic gearboxes but have just ordered a metal one from Mato.
Cheers
Mario
Cheers
Mario
I was mainly referring to the "treatment" side of things, as in PTFE (Teflon) coated gears for durability and quietness without a need for any liberal lubrication such as grease or oil. Come to think of it, I'm pretty sure that car spares places also sell a PTFE grease treatment as well, that should cover all bases.
Cheers
Mario
Cheers
Mario
Two issues: 1) I agree with Richard, takes grease to stay on the gears while whear-in. 2) Teflon in oil treatments takes heat (something line 400 degrees F, I think) to bond the teflon particles to the metal bearing surfaces.
Oops,,, 3) you don't apply teflon until after wear-in (break-in) period.
You can get an aftermarket teflon spray on treatment, but I doubt that the benifits would be worth the time, effort, and costs.
(I use a S&W gun oil, with teflon additive, on stainless steel semi-auto pistols. Doesn't appear to do a thing over other oils made for stainless, no coatings or anything like that...)
nice idea though....
Best to all,
Splat
Best to all,
Splat
