sagging
Hi does anyone have any ideas how to stop the bottom half off the turret on the leopard a6 sagging from the top half? it looks ugly at eye level an sometimes rubs the grills an scratches the paint off.
i want to put in a screw can find find anywhere to put one with the mfu inside, but then it will have to be undone an done up when i put the battery in?
thanks Chris
thanks Chris
Hello Chris
Had the same problem. I added small bolts in the side just to the side of the stowage basket at the lower edge on both sides to 'firm up' the turret plate alignment with the turret top - works great and clears the rear deck fine.
You can see the bolt in the pic below (just under the antenna next to the stowage basket).
WA
Eric, do you have additional pictures of what you did with your Leo as I am having the same problem on my Leo. The rear turret is sagged enough to scrap the grills. If you have additional pictures you can take to show in detail what you have done, would be appreciated.
