HL tiger info needed.
Old 07-19-2007 | 11:40 PM
The_Stuff's Avatar
Default HL tiger info needed.
okay, i screwed up. should have taken pictures.
can somone show me a picture of th wiring from the underside of the turret? i need to see the order of the wires to solder back to the 3 wire mini board there. also of the turret gear. i think i figured out what screws they are, just want to make sure.
and yes, 1/2 hr+ on the search function.
Old 07-20-2007 | 01:00 AM
swathdiver's Avatar
Default RE: HL tiger info needed.
There's no set way on my tanks, whatever the factory workers did. You'll have to trace the wires back to the big connector.
Old 07-20-2007 | 07:29 AM
The_Stuff's Avatar
with the use of a battery i figured it out. black is neutral then white is + for barrel leveler, red is + for shooting. then with the help of the the main faq from here, i traced the wires back! now i just wish it was easier to fix the idler issue.
