I wonder........
what HL tank would climb the steepest incline....?
if you where to test using a long board covered with a grippy surface like a rug or rubber like place mat and use the same battery for the same wieght in each tank ...wonder what tank would be able to climb the steepest incline before it starts to tip over?
Just a little something that i was thinking of
That type of test would be interesting,but it could also be a concern on how well a board would hold up with a maxium amp getting applied to it.The slip clutch and the ability for the tracks to slip as easily as they do may save a lot of trouble with blowing a board.
For such small motors and the stock gearing,have allways been amazed at their performance level and ability.
BIGMIG
BIGMIG
