Metal track pin removal
Hi all. I tried a search but couldn't find an answer to this question. Maybe I phrased it wrong, because it seems like something that should be a common question.
I bought a HL Panzer III and metal track upgrade a few weeks ago from Mato Toys. When I tried to install the new tracks, I could not figure out how to get the pin out. When I took the plastic ones off, the pin pushed out relatively easy. I also have a Tamiya Tiger with crappy metal tracks and the pins push out on them fairly easily. Is there a trick for getting the tracks loose, or should I take the drive gear off, install the tread and then try to line up the screw to reinstall it all?
Thanks!
Thanks!
RE: Metal track pin removal
you should be able to push the pin out with a thumb tack or paper clip. One side is scored and the other is smooth. Push from the smooth side. The T-81 tracks are a real bear, but Pz III and tiger are push-outs.
On the plastic tracks and my other Tiger tracks, they are smooth on one side and scored on the other. On the Panzer III metal tracks, both ends look "mushroomed" out to keep the pin from falling out.
ORIGINAL: speedpro440
I kinda apply presure to the tank and force the suspension down while moving the tank forward to ease off the tracks like a bike chain. I've tried the pin trick but wow is it hard as the pins don't want to budge. I know it's not ideal but for me it's quickest and safe as i've cut my hand with the pin trick a few time with too much force.
