T-34 Mod Question
Old 01-07-2008 | 08:50 PM
Fireman Tim's Avatar
Default T-34 Mod Question
When you guys swap HL boards into WSN/Trumpeter T-34s, do you use a HL tranmistter too or the stock transmitter?
Tim
Old 01-07-2008 | 08:56 PM
blitzkrieg65's Avatar
Default RE: T-34 Mod Question
Use the Heng long, the crystals are designed specifically for those boards and you can control all the functions!
The Blitz
Old 01-07-2008 | 09:05 PM
Thanks, probably a dumb question, but I thought I'd ask anyway.
Tim
Old 01-07-2008 | 10:32 PM
wackywheelz's Avatar
Heres my latest guide, HL S&S into WSN T34:
[link=http://members.iinet.net.au/~wackywheelz/]HERE[/link]
Stock transmitter is ridiculously big! HL one is much better, and the tank overall is a trillion times better than in stock form - bonus is your gearboxes will last longer because they're no longer getting jolted by the stock stop/go electronics
Old 01-07-2008 | 10:37 PM
Wow Wacky! Thanks for the guide. T-34 S&S for Dummies!
Old 01-08-2008 | 07:37 AM
Wacky
Did you buy the individual Hen Long parts or strip a tank? If you stripped one, which one would make a good donor candidate?
Tanks
Old 01-08-2008 | 07:45 AM
I get my parts cheap from a local HL shop, I'm not much of a "buy-something-to-rip-parts-off-it" type guy, I just get what I need to do the job.
If you had to get a donor vehicle, I suggest Bulldog or Pershing, as they have a longer gearbox output spline than Tiger/Panther/Panzer, which makes it easier if you ever wanted to get rid of the stock plastic T34 gears and adapt metal HL into them. Still do-able with the axis vehicles, so yeah any or either
You can always make the electronics removable so they can be switched between tanks easily, thats how I tend to do it - then you're not disabling the donor tank, which will still be good for a static tank
