Rookie's Panzer III J
ON, CANADA
Yes, another Panzer III build [:'(], but hey I need the input and advice from all you vets out there.
This is what I want to build:
A Panzer III J from the Patton museum.
Here is what I have done so far:
Drilled out the side vents and moved the antenna to the side
Moved the volume switch to the rear
I also gutted the airsoft cannon, flipped the side turret hatches, removed the smoker unit and moved the speaker to the back.
Still have photo-etched grill covers, a 39L/60 barrel and 25mm cooling fan coming. DBC/U to be ordered soon.
That's an H not a J. Note that the H has a different rear end above the mufflers and the last two vent covers are much smaller then the L. The transmission access doors are different and it doesn't have the hull side extensions with the towing eyes. Take note of the square radio operators machine gun compared to the round one used on the J and later tanks. Heng Long is going to release an H.
I don't know the history of this tank, it would be quite a survivor to have lasted from its production as late as July '41 to be around in '43 to have the Schurzen installed. Was this a capture from Normandy? Where is it located?
Are you going to delete the spaced armor mantlet and use those new adjustable idlers?
ON, CANADA
Wow. You guys noticed a lot more than I did. (Gulp!) It does seem to be a frankenstein of a tank. I don't think I will try and duplicate it entirely. Perhaps I should rethink it.
Fireman Tim. I like the pic's of your fullsize "donor" tank...Some beady eyed people have spotted iregularities with you "donor" example. That's how good this forum is. It's full of people that have an amazing breadth of knowledge and you have all of this free of charge.
I'm very pleased you posted the pic's of the fullsize PZIII as I have a few questions to ask. One of them is the position of the return rollers... Is the middle one higher than the front and rear one. Or are they inline and angled down towards the front of the vehicle. I hope this forum can help us with this.
I know I seem to be focusing on the return rollers, but I probably think we both need some help here. I think the way the tracks sit on the tank is pivotal in the way it will look when you have got it finished.
Gigantohawk.
Gigantohawk.
ON, CANADA
Well I am sure not the person to answer those questions.
LOL.
Here are a few more links I found regarding the tank. Enjoy.
[link]http://www.armorfortheages.com/PanzerIIImainpage.htm[/link]
[link]http://www.youtube.com/watch?v=wKZUMr5vyNc[/link]
LOL.Here are a few more links I found regarding the tank. Enjoy.
Ahh so that's an F that was picked up in Normandy and brought back!
Gigantohawk: The rear roller looks slightly higher then the middle and the front on is maybe an inch or two lower? Blow up the pics and take a look.
Swathdiver...That's the kind of info I'm looking for .You have a keen eye there my friend. However, the Germans on Panzerketten forum disagree with us. They seem to model the return rollers differently. By that I mean, middle roller higher than the the front or rear. In other words, front roller lifted 2mm, middle lifted 4mm and rear lifted 3mm. But I go along with you, I think the rollers are more or less in a straight line in a slope down towards the front roller.
Gigantohawk
Gigantohawk
ORIGINAL: gigantohawk
Gigantohawk
Gigantohawk
Geoff
Guys,
I am planning a trip to the Patton Museum in the very near future. Rest assured I will take many pictures. If anyone has some specific questions or picture requests I will try to meet them.
It's hard to tell if the sponsons are bent but there is less clearance above the rear roller compared to the other two. That would suggest that they slope slightly downward. I've seen the Panzerkettan post before, it's an excellent build.
Wait a second! Patton museum says this tank is an F right? While the Schurzen blocks the rear turret plate the forward shock absorbers are where they should be for an H or later model. Ausf G and earlier had this shock mounted further backward. They moved it up because the H introduced the new 400mm wide tracks, they were heavier and needed the support closer to the sprocket. I'm not at home right now, what do you think is the hull an F or H? Are there any pics on the net showing the back of the turret? G and earlier were smaller with the cupola sticking out of it.
gww...your eyes don't deceive you. the third photo shows the middle roller higher than the other two. So on that note I stand corrected.Having said that I had'nt focused on the third picture. But that was probably due to the fact that I was enjoying my third bottle of Peroni at the time.
Gigantohawk
Gigantohawk
referance the return rollers go to blueprints.com they have scale drawings of panzerIIIs it may be that some ausfs have rollers in line some may slope foward the only way is to blow up the blueprint and measure.
971wright I've looked at the-blueprints.com.It appears to me that the rear and middle are at the same height but raised in relation to the H/L rollers.The front one is also raised in relation, but lower than the other two...EEEEK, I need help,I've got new metal rollers,sprocket,idler + tensioners and suspesion arms on order. Gentlemen I don't want to mess up here....HELP!!!.
Gigantohawk
Gigantohawk
ORIGINAL: Fireman Tim
Oh yeah, and have some fun at the same time too!
Fireman Tim. This post alone should tell you how much help you can get with this forum and I apologise for partly hjacking it with my obsession on "ROLLERS".
Panther F, you're dead right it's not a contest.
I suppose it goes that way sometimes...We can't see the wood for the trees and then a sensible person comes along and pulls us all back into line.
Oh, you had the best intentions I'm sure, and it wasn't aimed at any one person at all. Even I can get consumed with too much detail and information.
The biggest challenge would be to duplicate the turret schuerzen and to be in scale. Everything else would be just gravy.
ON, CANADA
Thank you all for the encouragment. It is a very unique tank for sure, not one that I would want to duplicate to the "T".
I think what I will do, is try to duplicate the colours on an Ausf L with Turret Schurzen.
This might be a little late and more expensive than you wanted to go, but tankzone has some conversion kits, including the Ausf J.
[link=http://www.tankzone.co.uk/cart/hl_p3.htm]http://www.tankzone.co.uk/cart/hl_p3.htm[/link]
With that many possiblities, how can you own just one?
ON, CANADA
Thanks for the help. I think I will keep it a ausf L (I got the aluminium barrel on order) with some turret schruzen. Its my first RC Tank build, so I think I need to keep it simple.
