 Relocating Antennae on Sherman >
Old 02-18-2008 | 05:30 PM
Default Relocating Antennae on Sherman
I want to relocate the RC antennae to the turrent on my Sherman. Is this a difficult mod? Does anyone have a tutorial on how to do it?
Old 02-18-2008 | 06:13 PM
Panther F's Avatar
Default RE: Relocating Antennae on Sherman
What radio are you using? You can always place a fake antenna in the turret and just spread the antenna out. Adding a 'mast' would result in signal error. All my tanks (check my gallery) are like this:
Plus, it's one less wire!
Old 02-18-2008 | 08:35 PM
Or you can do the same but coil it ard a straw with sufficient spaceing btw each coil and put the straw in the hull away from motors. I used to wire it up to the pershing turretand even made one to replicate the flexible part that came withthe pershing but after getting a spektrum in there, the antennas are now for show. Will find a nice pic of the turret one of these days. Anyway a friend of mine has his in is sherman turret, as the antenna base is in a hard to reach place if you glued the turret together its a lot of hassle to get it there.
