 T34 CONVERSION TO HL-HELP >
Old 03-18-2008 | 02:59 PM
Default T34 CONVERSION TO HL-HELP
Hi guys. I was trying to convert my WSN T34 to HL BOARDS. I managed to get the tank running and it worked great but I don't know what wires go where to hook up the Turret rotation/barrell elevation, and the sound. I also discovered another problem with the HL circuit board I got from MATO. These boards are the TKRX13 boards. They don't have those ports to plug the T34 Turret Rotate barrell elevate control. I am at a loss on how to resolve this. Looking at Wacky's T34 coversion the boards he used were the TKRX14. I guess my question is where can I get those boards? I really don't want to have to shelve my T34 as I like how this tank looks and runs. So basically if anybody has a pic of what wires go where or where I can get the TKRX14 boards that would be a great help.
SNOWTANK
HL TIGER1-HL PANTHER-HL PZ3- HL WALKER BULLDOG-HL PERSHING-MATTORO KINGTIGER- MATTORO T34/85
Old 03-18-2008 | 03:08 PM
ArmChairGeneral's Avatar
Default RE: T34 CONVERSION TO HL-HELP
Hey Snowtank, I stopped at the same point with my T-34, I put the Panther boards in there and got the thing mobile and turret turning but not the other features. Hopefully someone can post some pics to help. Did you order a Panzer IV?
Old 03-18-2008 | 04:26 PM
The pins that the connectors attach to on one side of the board, should have a corresponding solder on the other side. I'll have to check when I get home to make sure. For the turrent and sound, I just followed Wacky's photos from http://members.iinet.net.au/%7Ewackywheelz/t34/
Old 03-18-2008 | 04:37 PM
Ok thanks. I think I can sort out the sound part of it. Just seems that there are extra wires either from the Turret elevation/Rotation or from the Mato board plug. I tried to match the colors but ended up with extra wire from the Mato board so I knew I was in trouble.
I sorted out the wires and labeled them as best I could but I am not sure if they are correctly labelled.
SNOWTANK[]
Old 03-18-2008 | 04:38 PM
I been eyeing a Panzer IV and I think I will order one tonight. I have space on the shelf for ONE MORE TANK.
Old 03-18-2008 | 05:10 PM
I am familiar with the "One More Tank' syndrome, I lump it in with Santa Claus and the Easter Bunny, things that don't exist !
Old 03-18-2008 | 05:53 PM
wackywheelz's Avatar
Did you manage to get it working? I'm willing to help directly if needed...
Old 03-18-2008 | 06:38 PM
pattoncommander's Avatar
hahahaha that what I said 33 tanks ago[>:]
Old 03-18-2008 | 08:54 PM
No I shelved it because I don't know how to hook the current boards RXT13 to it. I tried looking at a Pershing rebuild that had the same board but must be even an older version as the board itself is different again. Totally confused now.
I had snipped off the plugs from the T34 wires because the boards didn't have the ports for them. I thought I could wire them in directly but theirs defintily a mismatch of wires. I tried to sort it out but it got confusing and frustrating. So frustrating that I ordered to a PZ IV to make me feel better. Still though the thought of 1 Tank not working in my collection and it's a one of a kind because it's the only Russian tank is dissappointing. Can you restore my faith?
Snowtank[&o]
Old 03-18-2008 | 09:35 PM
Did you look at my [link=http://members.iinet.net.au/~wackywheelz/]guide[/link], specifically the [link=http://members.iinet.net.au/~wackywheelz/t34/Dsc03300.jpg]wire/pinout pic[/link]?
Old 03-19-2008 | 03:06 AM
borealis's Avatar
wackywheelz, what if you 'shoot' using the left stick (airsoft)? In those 2 videos I only see the simulated shots from the 'k' button.
Old 03-19-2008 | 03:41 AM
I have the Left stick up, or airsoft wiring to be specific, operating the barrel recoil ([link=http://youtube.com/watch?v=8KVmdgE811g]video[/link])
Old 03-19-2008 | 05:43 AM
borealis's Avatar
You did press both the left stick and the K button, is it?
And does the muzzle led flash too? I could not see it in the video.
Old 03-19-2008 | 10:08 AM
I didnt have the LED hooked up at the time. Yep I pressed up stick and K at the same time, to be honest I cbf syncing them really
Old 03-19-2008 | 02:37 PM
Yes I looked at that guide. I will look at it again and see if a "Clearer Mind" will make sense of it. I will get back to you on that if I get stuck again.
SnowTank
Old 03-20-2008 | 04:04 AM
Snowtank: I did this a little while ago and wrote about it on this forum:
Try here:
http://www.rcuniverse.com/forum/m_68...tm.htm#6890791
I'm still going back and doing bits and intend one day to sync the recoil / flash / tank jerk / sound.......one day!!
