Tamiya sherman question
Old 03-19-2008 | 01:57 PM
Soulfly3's Avatar
Default Tamiya sherman question
what's a decent radio and reciever for that tank with the TBU.
Thanks.
I was looking at something like this.
[link=http://cgi.ebay.com/FUTABA-4EX-4-Channel-FM-W-4-S3004-Servos-38-NEW-IN-BOX_W0QQitemZ120234142809QQihZ002QQcategoryZ34056Q QssPageNameZWDVWQQrdZ1QQcmdZViewItem]clicky[/link]
Old 03-19-2008 | 02:29 PM
StumpyBloke's Avatar
Default RE: Tamiya sherman question
Thats the one I use on my Tamiya Leopard 2A6 and it works a treat. I dont have the TBU though but dont see why that would make any difference.
Old 03-19-2008 | 02:54 PM
Soulfly3's Avatar
ORIGINAL: StumpyBloke
well thank you for the feedback mate!!! I greatly appreciate it. I'm now thinking of getting a Tamiya Sherman. This hobby is very addicting!!!
Old 03-19-2008 | 03:37 PM
Panther F's Avatar
It's a fine radio to use, but if you are to use it for just one tank, the Futaba 4YF-FM is what I use and might be a little cheaper. This link said it's for 'park flyer use', so make sure you get a ground frequency.
HTH
Old 03-19-2008 | 03:45 PM
My Feedback: (12)
Soulfly3,
I'd take a very close look at that radio before you purchase it. It appears to be a 72mhz setup on channel 38 (72.550mhz), which in the U.S. is for "air use" only. You'll need a surface frequency radio to go with such as a 27mhz, 50mhz, 75 mhz, or a 2.4ghz radio. 75mhz or 2.4ghz is what most use. Here's a handy chart to sort out frequencies and channels [link]http://www.easyrc.com/radiosystems/radiosystems5.html[/link]
Old 03-19-2008 | 04:26 PM
Soulfly3's Avatar
ORIGINAL: Jeff489
Soulfly3,
I just noticed on the receiver too 72mhz.
Sorry if I sound like such nooblet!! From years of running cars, I never had the need for a 4 channel radio.
Thanks for the help.
Old 03-19-2008 | 09:24 PM
ksoc's Avatar
Good luck with your Sherman
Once you get your tank up and running, don't forget to come check us out! Our club run tank battles with Tamiya and other tanks. We are probably within about 30 minutes from your location.
If you get a chance, we are trying to do some demos at RCX at the Fairplex on April 19th & 20th.
www.socalareatankers.com
www.rcx.com
Old 03-19-2008 | 11:00 PM
nemesis4u's Avatar
My Feedback: (77)
SOULFLY3,
CONGRATS on your decision to get a TAMIYA M4 SHERMAN... YOU WILL TRULY LOVE THE MODEL TANK!!! IT IS SO COOL!!!!!!!!!!
CHECK THIS INFO OUT!
105 HVSS photos:
http://www.taskforcebaum.de/geraet/m4a3_105.html
http://www.sixtharmygroup.com/portal...bum=371&pos=16
http://ww2drawings.jexiste.fr/Files/1-Vehicles/Allies/1-USA/02-MediumTanks/M4-Sherman/M4(105)-HVSS.htm
http://personalpages.tds.net/~shannaandrobert/M-4.htm
http://www.ww2incolor.com/forum/showthread.php?p=90126
http://mailer.fsu.edu/~akirk/tanks/U...nks/M4/M4.html
http://www.shurlach.fsnet.co.uk/m4.htm
http://www.jedsite.info/tanks-sierra...an-series.html
TAMIYA UPGRADE detail PARTS for the M4 if you want any for your own...
ALL THESE ARE THE SAME WEBPAGE just different categories by brand for the M4
http://www.customrcmodels.com/shop/r...upgrade_sh.htm
these are through the main customrcmodels webpage but are through the ETO ARMOR LINK PAGE.
http://www.etoarmour.com/products.php?ViewCategory=8
http://www.etoarmour.com/products.php?ViewCategory=11
http://www.etoarmour.com/products.php?ViewCategory=12
AGAIN... THE TAMIYA SHERMAN WORKS PERFECT OUT OF THE BOX.. You may just want to add a bearing set while assembling the wheels...
These are the types of glues you can use for "welding the parts together"
these are the SAME KINDS....JUST DIFFERENT LABELS!!
http://www3.towerhobbies.com/cgi-bin...&I=LX0998&P=ML
http://www3.towerhobbies.com/cgi-bin...&I=LXHU34&P=ML
Your RADIO just choose a surface frequency!
http://www3.towerhobbies.com/cgi-bin...=LXEFJ4**&P=ML
AIRCRAFT ENGINES IN TANKS:
http://www.enginehistory.org/featured_engines.htm
OK... A LITTLE INFO... HAVE FUN
BTW... YOu can order your new M4 SHERMAN direct from me here in Texas.. I have them instock as well as Tamiya Battle units and Battery packs!
http://www.vqwarbirds.com/aircraft.html
=nemesis4u
TEXAS ARMOR ASSOCIATION
