styrene stuff
Old 05-01-2008 | 07:56 PM
Default styrene stuff
I need help guys what is styrene (sorry for spelling) but what is it called by sides this. I asked in hobby lobby but of course they did not know what i was talking about. I then went to actual model store that built models and yea you guessed it don't know what it is or heard of it. I have seen some plastic type foam board but i didn't think this is the stuff. It was very flexible, i believe they called it foam board. I see that Styrene is used quit often and would like to have some for buildings and possible future builds. As i under stand it it comes in different thicknesses. Now where can I find some and what is another name for it here in the United States. OORAH DEVIL DOGS DO OR DIE.
One shot one kill Sniper67.
Old 05-01-2008 | 08:01 PM
swathdiver's Avatar
Default RE: styrene stuff
Evergreen is a brand of styrene. Most local hobby shops have a selection usually on a rotating display and you can get it from our website sponser here at Tower Hobbies. They all different shapes, sizes and thicknesses.
Old 05-01-2008 | 08:08 PM
smittyrob's Avatar
Another name is plastic
http://www.dhcinc.com/evergreen.htm
http://www.plastruct.com/
Old 05-01-2008 | 10:13 PM
Its a little bit scary that your Hobby Lobby didn't know what styrene is...[X(]
Old 05-01-2008 | 10:59 PM
pattoncommander's Avatar
Sheet styrene can be found in any hobby store...look for it hanging on rotating displays or on the wall. It comes in various forms, plain, patterns such as roofing, bricks, sideboards etc etc. and various thickness, so that you can build almost anything with it. A hobby store that doesn't know what it is, isn't much into hobbies. Use Zap a Gap or super glue with it.
Old 05-01-2008 | 11:51 PM
ORIGINAL: pattoncommander
Just wanted to add to the above that walmart was selling packets of 6 or 7 small tubes for a dollar per packet,and if you have dollar stores in your area they are also good places to buy the packets of super glue.When you buy them this way it is a cheap source of glue.Also if you use "kicker" and get it in your glue supply,it's better to have messed a small tube than a more exspensive bigger bottle of CA. BIGMIG
Old 05-02-2008 | 12:08 AM
streetsquid's Avatar
Styrene, is just the shortened name for polystyrene which is a type of plastic. Most decent hobby stores sell smaller sized sheets (8X10) in a variety of thicknesses, ranging from thinner than a sheet of paper to about 1/4" thick. It is usually sold with both the front and back side being smooth, but there are also many manufacturers that make styrene with patterns that replicate clapboard siding, diamond plate, shingles, tile, etc. Styrene is almost always white in color and is easily glued using plastic solvents or super glue. Beside sheet goods styrene is also sold in extruded shapes such I-beam, angle iron, "T" section, "C" channel, straight strips, tubing and various shaped rod stock.
Other suitable plastics for model building would be butarate (usually dark gray in color), ABS (usually black or off white in color) or sintra which comes in a variety of colors, acrylic or polycarbonate which are both clear. All of these plastics have different characteristics and chemical make-ups, and each is well suited for specific things. Sintra for example is most often used for out door signs, while polycarbonate is used to make bullet proof windows an other nearly indestructable items. Only styrene is readily available at hobby shops, while the others usually require a shopping trip to an actual plastic supplier.
If you go on-line you can look up the 2 biggest suppliers of stryene to the hobby industry Plastruct or Evergreen Styrene to learn more.
The Squid
PS If you're local Hobby Lobby didn't know what styrene was..........I'd suggest you find a new hobby shop to spend your money at
Old 05-02-2008 | 07:53 AM
pzrwest's Avatar
I use to get large sheets of .060 sheet styrene from a building supply company. It was the blank section from a tub surround
Old 05-02-2008 | 09:28 AM
Ern's Avatar
Ern
My local RC shop also did not know what it was. I settled for an overpriced sheet of lexan to build a grease splash guard for my gears. When I got home I checked eBay and there were several auctions for sheet styrene. If you can't find what you need locally, check on the 'bay.
Old 05-02-2008 | 06:02 PM
Thanks guys now I know to what at least look for in the hobby shops. Like I said they did not know. I live south of Houston, TX Angleton, TX to be exact and nobody around here seems to have any. I have been all over and yes it is sad when a model shop of all places does not have any the only real good place had closed up due to the internet sites took away a lot of biusness and they had any thing you would want but at the time i did not need it. Well on th look out again. Thank you for the fast replies and the great help you all gave.
One Shot One Kill Sniper 67
