 MATORRO STURMTIGER BATTERY ? >
Old 05-18-2008 | 10:44 PM
Default MATORRO STURMTIGER BATTERY ?
Does anyone know where to find spare or replacement batteries for the matorro sturmtiger?
thank you
John
Old 05-19-2008 | 01:47 PM
Default RE: MATORRO STURMTIGER BATTERY ?
If you just want batteries and don't care that it doesn't have the "Matorro" logo on it, here's a few that a little better than the stock Matorro batteries.
http://www.all-battery.com/index.asp...S&Category=186
You can also find some on Ebay.
Old 05-19-2008 | 02:37 PM
Leon01's Avatar
Since this is open what is a good battery to run in A HL or Torro tank. For long running time The stock battery seems to last only about 20 min they are 1700mah or so. Being new to RC I'm not to sure about mah only is better or nicd vs nimh
Old 05-19-2008 | 03:26 PM
Thanks for the replies but the Sturmtiger has a strange 3 wire connection that is not like the Heng Long or Tamiya connections. Does anyone have a Sturmtiger with this connection?
Old 05-19-2008 | 03:58 PM
That's odd, do you have a pic?
I don't have a Sturmtiger, but I assumed that HL/Matorros all use the Tamiya-type connectors.
Old 05-19-2008 | 06:27 PM
mariomart's Avatar
The Sturmtiger has 3 wires as they have tapped into one of the battery cells to provide a lower voltage to the main board and a higher voltage to the motors. You should be able to do this yourself if you feel confident.
Cheers Mario
Old 05-19-2008 | 06:55 PM
Thanks Mario, I guess when this battery goes I will take it apart and figure something out as it seems that they do not have replacement batteries at this moment. I wished they just used the same setup as Heng Long.[]
