Smoke unit
Old 06-26-2008 | 07:48 AM
Default Smoke unit
Hi All,
Tried to take a bad smoke unit out of a walker bulldog (HL). I cannot get the tubes off I broke the plastic fittings. How do I get the plastic tube for this? Is it heat shrink? What ID is it? How should I do this.
Help. -Jack
Old 06-26-2008 | 09:30 AM
Default RE: Smoke unit
Jack,
This is your lucky day. I just got my order in with your Walker tracks and I asked for some extra smoke tubes. I'll throw in a pair for you with your tracks and gun.
John
Old 06-26-2008 | 09:43 AM
I had to replace mine on my Bulldog. My father uses oxygen, the tubing is perfect size for that .So if you know some one who uses it and they usually replace the tubing every so often, ask them to give you the old tubing. He gave me a 50 foot length so enough to last a lifetime I would say
Old 06-26-2008 | 10:04 AM
How do you remove the old tubing?
Old 06-26-2008 | 10:13 AM
if its just the tubing that's broken then any clear tub would work. To remove the tube from the smoker I used a soldering iron to head the tube. It pulled rigth off. I thought you had broken the actuall plastic attachment to the smoker.
Old 06-26-2008 | 10:31 AM
i did break the plastic attachment to the smoker. Do you have a spare smoker?
Old 06-26-2008 | 10:55 AM
I do actually PM me and we can discuss it
Old 07-09-2008 | 12:19 PM
HI. Do you have one or 2 more smoke tubes with the 90 degree elbow or tell me where to find them? THANKS! -Jack
Old 07-09-2008 | 02:50 PM
Did you not get them. I put 2 in the box with your metal tracks.
Old 07-10-2008 | 10:00 PM
You can get tubing that small at your local drug store that sells oxygen tank supplys.
Jimmy
