 HengLong TigerTank problem! >
Old 08-19-2008 | 11:16 AM
Default HengLong TigerTank problem!
Hi there!
I've got an Henglong Tigertank. But it's problem with the gearbox, some of the plastic gear are "slipping" over. What should I do? The Tanks is new. I will not change gearbox. Any Idé's?
Old 08-19-2008 | 11:20 AM
blitzkrieg65's Avatar
Default RE: HengLong TigerTank problem!
ORIGINAL: MacGyver1958
Hi there!
It sounds like alll you need to do is tighten her up, or lock down the bushing with the JB weld, but if you have picture that would help??? Oh and the plastic gear box does come with a slip clutch are you running through weeds and this is happening more dretails and pictures and we can get you back in service!
The Blitz
Old 08-19-2008 | 11:25 AM
wackywheelz's Avatar
Might need to do the [link=http://members.iinet.net.au/~wackywheelz/tanks/guides/clutchmod/]Clutch Mod[/link]...
Old 08-19-2008 | 12:05 PM
swathdiver's Avatar
Dump the plastic gears and go metal.
Old 08-19-2008 | 12:14 PM
So i should clean up the clutch?
Old 08-19-2008 | 04:51 PM
Ern's Avatar
Ern
If it's constantly slipping and you hear that terrible grinding noise, especially when turning in grass or carpet, etc, it's the slipper clutch with the nylon gears. It is a safety feature to prevent frying the circuit board. The clutch mod that Wacky is referring to involves taking apart the gears, cleaning off all the grease, and super gluing the clutch piece to the gear to stop it from working. You run the risk of overheating the board, but no more than running the tank with metal gears. Either get used to the sound, glue the clutch as in Wacky's link, or replace with metal gears. I have two Tigers, one with plastic and one with metal gears. The metal gears are noisier than plastic. Depends what you want. The cheap fix, and if I were you, glue the clutch first and try that and save the $30+ for metal gears unless you plan on upgrading anyway. Just be careful and watch for sticks/rocks getting caught in your tracks. The clutch allows the gears to continue turning thus preventing the overload. The glued clutch/metal gears will keep trying to turn when they can't and that's when you have problems.
Good luck with it!
Old 08-20-2008 | 09:17 AM
So It's not dangerous! Thats good. Thank you very much. I think I will get used to the sound. Maybe glue it later.
