elmod in uk ?
hi all ,does anyone stock elmod in the uk, if so what would i need ,im only after better sound, and how much would it cost to kit out a hl tiger
regards cliff
regards cliff
CA
Well the EL MOD guys don't mind me selling world wide so you can compare my prices with theres!
To upgrade to EL MOD & Sound keeping the stock radio would be $133.20 for the Booster/ TLS/ HL (M) for metal gears
Then you need to add the Blaster II and that is $ 139.00 with high end speaker!
Total with shipping to England = $ 282.20 USD
The Blitz
http://www.rctankwars.com/products.php
Here is the EL MOD site out of Germany
http://www.el-mod.de/
CA
ORIGINAL: icemonkey
my tiger has all metal upgrades so would the standard booster be up to it ?
The only time you would need the After burner or to buy the BigBooster is if you are planning on running more powerful motors!
The Blitz
CA
ORIGINAL: icemonkey
also i have the recoil unit fitted with muzzle flash,is this still compatable
EL MOD has its own flash point in their board, and there is a spot to connect a Tamiya recoil unit! I assume that you are reffering to the all in one recoil unit, I want to say yes,
because voltages are simuliar but I need to test it and verify! I have two of those recoil units in house I just need to get the time to fit it and check it, I should be able to have that
tested out by Mid september at the latest! I will keep you posted!
The Blitz
yes its the all in one for the hl ,its fitted to my tiger in the pics in my post ( my first tiger),if it all checks out i will go for it, do you do paypal?
CA
ORIGINAL: icemonkey
The Blitz
RCTAnkWars.com
hi blitz just to verify the recoil unit i have is the one for the hl tiger ,it has the built in elevation unit as well,is this the same as the ones you have,please say yes
regards cliff
regards cliff
CA
ORIGINAL: icemonkey
regards cliff
regards cliff
ITs the one used in this post, gotta get some shut eye check back later!
http://www.rcuniverse.com/forum/m_7890723/tm.htm
CA
ORIGINAL: icemonkey
regards cliff
regards cliff
The Blitz
CA
ORIGINAL: icemonkey
cheers for that ,when can i have it,
The Blitz
CA
It is just the next generation, they are going to new memory card and ease of use for loading files but the specs are the same or very simuliar! Still need to get my spec sheet on it, but that is the word I got from the guys!
The Blitz
The Blitz
