Modified HBU
Old 10-07-2008 | 06:59 PM
YHR's Avatar
YHR
Default Modified HBU
I modified the Heng Long HBU to work with the Darkith DBC. I added LEDs and packaged all up in an apple. Works very well.
ID:	1047771   Click image for larger version
Old 10-07-2008 | 10:14 PM
kclank's Avatar
Default RE: Modified HBU
ORIGINAL: YHR
OK now you must show and tell all. gawd i love this site. so many talented people.
Old 10-08-2008 | 12:52 AM
YHR's Avatar
YHR
If you go to Darkith's website he basically lays it out for you. Two sets of two LEDs wired in parallel with each set going through a resistor in series to limit the voltage to each set of LEDs. I replaced the Heng Long Sensor in the tower with a 38 Mhz sensor. Everything works great. I used an old DBU board that I had screwed up some of the wire tracing on for this one, but I guy could get some perf board and wire it up as well.
Mato sells the Sensor for $11, and then another $5 for LED's and resistors, and you have a reasonably priced battle unit.
Old 10-08-2008 | 07:05 AM
That looks sharp. I wonder if I should consider a PCB with just the LEDs & resistors, plus a spot to mount the HBU. Could even come packaged with a sensor to replace the stock HBU sensor.
Hrm...
D.
Old 10-08-2008 | 08:30 AM
RCCOMMAND's Avatar
ORIGINAL: darkith
Hrm...
D.
Now you're talkin'.
Old 10-08-2008 | 08:49 AM
YHR's Avatar
YHR
ORIGINAL: darkith
Hrm...
D.
I think that would be an excellent idea.
Old 10-08-2008 | 12:37 PM
kclank's Avatar
do consider, do! please.
On the other hand locating the leds in place of, in position of periscope would be cool and should not offend the mo[img][/img]re purist battlers.
Old 10-08-2008 | 01:06 PM
Matdragon's Avatar
very nice clean job their, nice to see the old system being somewhat re-cycled rather than completely ripped out!!
cheers,
Matt
Old 10-08-2008 | 06:59 PM
YHR's Avatar
YHR
I repainted the unit. Looks a little more "factory" now
