rx18
Old 10-21-2008 | 03:32 PM
bubbajoexx's Avatar
Default rx18
does any one have pics and pinout for the rx 18 board
Old 10-21-2008 | 03:38 PM
Default RE: rx18
http://www.rctankwarfare.com/Forums/...pic,241.0.html Tthere ya go bubba, not pin outs but some good pics taken by me (can get more if you want)
Old 10-21-2008 | 03:39 PM
Banned
Default RE: rx18
Hi bubba
not sure if these will help you out http://www.rctankwarfare.com/Forums/...pic,241.0.html
a couple of posts down is a written guide too
Kind regards Rob
Old 10-21-2008 | 04:11 PM
Matdragon's Avatar
Default RE: rx18
he he same one lol
Old 10-21-2008 | 04:51 PM
bubbajoexx's Avatar
Default RE: rx18
thanks but pics a bit unclear I need to be able to read the lettering and need pin by pin pinout bought 3 of these boards to play with and I dont want to burn them out
Old 10-21-2008 | 05:07 PM
Default RE: rx18
Are the connectors labeled such as "A" "B" "C" (for example) for the pins/wires, or are they blank?
Might be small, but most connectors (maybe not Chinese?) have some sort of label for each pin.
Old 10-21-2008 | 05:55 PM
bubbajoexx's Avatar
Default RE: rx18
no there are not thats why you have to map them on the board
Old 10-21-2008 | 09:09 PM
Default RE: rx18
Hi Can RX 18 be used to replace RX 13?
Old 10-22-2008 | 12:43 AM
Default RE: rx18
it can be used to replace it but you need to make the motors use 2pin connector, the battery switch use 2pin connector and the speaker volume control use a 3pin connector
Old 10-22-2008 | 03:15 AM
Default RE: rx18
Hi Norse,
Thanks for your response. I guess I can solder directly if I can't get the connector. But how about the connector to the receiver board? Are the pinout the same?
Old 10-22-2008 | 04:36 AM
Default RE: rx18
Hi Bubbajoexx try Darkiths web site http://darkith.dyndns.org/~darkith/html/rx18.shtml
has full write up on the rx 18
regards pete
Old 10-22-2008 | 05:14 AM
bubbajoexx's Avatar
Default RE: rx18
now thats a start just need the rest the bottom plug thats not marked
Old 10-22-2008 | 12:45 PM
bubbajoexx's Avatar
Default RE: rx18
http://www.rctankhq.com/Downloads/Pr...g-Ground-2.pdf
found this today some may find it interesting
Old 10-22-2008 | 12:56 PM
Default RE: rx18
ORIGINAL: bubbajoexx
the bottom long plug is the turret one
Old 10-22-2008 | 01:20 PM
bubbajoexx's Avatar
Default RE: rx18
I know but i dont have a pinout yet for the plug
Old 10-22-2008 | 01:24 PM
Default RE: rx18
i think its the same as normal plug
Old 10-24-2008 | 02:00 PM
bubbajoexx's Avatar
Default RE: rx18
Xmas came early got some of my parts in today
stug gear boxes
rx 18
8 sound sound card kit
compact gearboxes
ID:	1058020   Click image for larger version
ID:	1058021   Click image for larger version
ID:	1058022   Click image for larger version
