 programing my !/16 Sherman >
Old 10-22-2008 | 04:04 PM
Default programing my !/16 Sherman
The instructions I have say move sticks up and down, is this the same forward and back wards. Left stick up and right does not work lights. Every thing work on self test.
Do they want 100% travel on every thing, I reduced throws and everything got a little flaky
when I did a reset.
On airplanes, up is stick back.
Darryl Usher
Old 10-22-2008 | 04:41 PM
Default RE: programing my !/16 Sherman
Visit here for clear instructions on how to setup the Tamiya Sherman: http://www.customrcmodels.com/Tanks/id92.htm
You will use the various trim tabs for the lights, firing the main gun and the machine gun.
Old 10-22-2008 | 08:39 PM
ksoc's Avatar
100 % travel - Yes.
Are you using a 2 channel or 4 channel radio? 2 channel requires a lot more fiddling with the trim tabs to work all the function.
I still have to look up the trim tab set up to get the lights to work
If you are still having trouble, let us know and I can dig out the manual.
