T-34 Upgrade help.
Just wondering what are the basic HL components i need to upgrade my T-34 to HL Standard, and what tools i must use besides the solder, and are there any online instructions?
many thanks
-Malachi
many thanks
-Malachi
BC, CANADA
I have done one , from this site
http://members.iinet.net.au/~wackywheelz/t34/
just paste this into your browser and here are instruction as well as pictures to go
BC, CANADA
Forgot to mention that I had to reverse the positive & neg lead on the two wires coming from the right motor Before I did that the Tank would only go forward moving the right Tranmitter lever to the right. it was weird, but after checking I discoverd the in full forward position, one track went forward the other went in reverse . It is trckey to re-solder the connection at the motors so I cut the two leads and re-soldered them and used heat shrink tubing . Works great now , even the Barrel illiuminated and the machine gun fire with out the Barrel going ip & Down
Its a really easy mod and works great. you do have to reverse the 2 wires on the right motor like 19th Alta said. The originall wiring config wont work with an HL radio.
ok, forgive my ignorance, so if i were to install the RX14 board, do i just fit the board reconnect the tanks default wires into the board or do i have to get a totally new gearbox etc etc?? (and is wires included?)
CA
The gearbox is OK, but you will need RX-14 board, receiver, crystals and heng long radio! You will need to change of the wiring some, but here is wacky's directions!
The Blitz
The Blitz
but the original wiring config works with the default remote? (with the s&s) and, (is it possible to keep the battery box?) since well, i have a good friend working at the energizer battery factory haha
