HL Tiger
Old 01-05-2009 | 03:46 PM
Default HL Tiger
Hi. I have read many reliability issues with Heng Long tanks, however, I am handy ith a soldering iron and screwdriver so I'm not affraid to rip it apart if I need to. Can anyone tell/give me advice what to after taking the tank out of the box? ( any checks, any immediate mods?), also what are the first things to change or modify mechanically as I would like to add 'metal running gear' but are there any issues/do's and don'ts?
thanks
Old 01-05-2009 | 03:55 PM
swathdiver's Avatar
Default RE: HL Tiger
The "search" feature is your friend! If your tank comes with metal gearboxes, take them out and break them in properly as per the FAQ. If your new tank comes with metal suspension mounts and screwed rather then pressed axles for the wheels you probably won't need the metal suspension arms. Metal tracks are cool and essential on a Tiger if you plan to run it outdoors on any rough terrain. The track links will break just like a real one.
If after a couple of hours of use you find that this hobby is for you, throw away the battery and buy a 3000+mah battery and peak charger, there's some good deals on 4200s and buy 2 while you're at it, one for you other tank. What other tank? No adult tanker owns 1 tank.
The newer tanks electronics are more reliable, that doesn't mean that things won't fail or break. It's always a great idea to have spare parts on hand to make repairs, crystals, boards, radio, smokers, etc. The smokers are a PITA and don't last. Plenty of posts on how to fix them. Again, the newer ones are better though.
Read through this and other tank forums, look at the builds to see what can be done with these machines. It's addicting and a lot of fun.
Hi
Cool your board!!! check the search feature and you'll find how this is done.
Then, metal gearboxes.
Then, metal suspension.
Then, metal tracks.
That's the order that I would do it in, ( I personally did it in a different order on my first tiger, with a lot of problems!!!!!!)
regards
Frank
Old 01-06-2009 | 02:12 PM
Hi guys
Thanks, it arrived today and I will have to rip it apart to see if it has metal gear boxes, if not I will invest in metal gearboxes/tracks/suspension and wheels.. and an RX18 board.. It has a smoke unit but I am not too bothered about that.. so in the coming weeks I'll be busy upgrading the tanks mechanicals and then I'll start on the appearance!!
Bill
Old 01-06-2009 | 09:24 PM
YHR's Avatar
YHR
ORIGINAL: emin8
Hi guys
Bill
Welcome to the insanity
