 how to wire a laser pointer??? >
Old 02-17-2009 | 08:00 PM
harryfish's Avatar
Default how to wire a laser pointer???
hey guys, tried the search function found nothing. if anyone knows how or even better have a pic.
please let me know. thank you
i have two pointers and i think i blew one already? any help would be great.
cheers
Old 02-17-2009 | 08:20 PM
Default RE: how to wire a laser pointer???
I would also like to figure out how to wire one with the gun function so when you are activating the gun motor the laser is on to locate the target, Right now I have one secured to my barrel It would be nice to have one hidden inside the tank.
Old 02-17-2009 | 09:40 PM
blitzkrieg65's Avatar
ORIGINAL: harryfish
cheers
Connect it too the wires that are hooked up to your safety LED, that is already wired into you gun! Depending on the volatage needed, you probably do not have to even add a resistor! If not enough power remove the resistor that is in line by the gun cut off switch!
The Blitz
Old 02-17-2009 | 10:23 PM
harryfish's Avatar
ORIGINAL: blitzkrieg65
ORIGINAL: harryfish
cheers
The Blitz
thanks for reply, but my issue is i can't get the laser to power up? where do i solder the +&- wires?
Old 02-18-2009 | 04:51 AM
Does this help? [link=http://www.rcuniverse.com/forum/m_7562199/tm.htm]http://www.rcuniverse.com/forum/m_7562199/tm.htm[/link]
