Gear Ratios File
Gear Ratios File
Hi Fellas,
My PC crashed right when I went to install a back up hard drive, go figure! Anyhow, I had sent several versions of my gear ratios excel file that I had sent to some of you. Phil sent me an older copy, I was wondering if someone had a newer one where I had recorded my speed tests on the Scale Speeds tab and I think it had the Sherman sprocket ratios calculations on the main page.
Send to [email protected]
Remove the nospam part of course!
Ohh, and it might have had the PZIV sprocket information listed too! I have received an older copy so if anyone knows the PZIV sprocket diameter please post so I can update this file if the other doesn't turn up.
RE: Gear Ratios File
Hi Swath,
Dont know if this is the right version... but check: http://www.4shared.com/dir/13644356/.../RC_Tanks.html
And dont forget to download the new El-Mod Sherman sounds in "EM Sound" map
Best regards
Jake
Best regards
Jake
Thanks Jake!
Can anyone provide the sprocket diameter of the Tamiya and Matorro tanks?
Also looking for gearbox information on the Impact and Tamiya boxes. Need to know pinion tooth count and all gears. Photos would be great help as I update the file.
