HL Tiger, Turret Problem
Hello all, my son decided he wanted to play with his HL Tiger that we bought him for xmas, (first time he's really wanted to use it since then) anyway, new batterries in the controller, fully charged battery in the tank and away we go, it went fine for about five minutes and then the turret started turning anti-clockwise without us moving the controller, it will go as far as it can go and then start clicking because it can't go any further, if you use the controller to turn it in a clockwise direction it will do that ok but once you let go of the lever it starts going back anti-clockwise again, i am mystified, i have taken the batteries out, turned it on and off, and used a different controller to no avail, any help please people, thanks
RE: HL Tiger, Turret Problem
You normally can't adjust the trim on the turret traverse but it sounds like the traverse trim pot is out of adjustment. Can you slide the trim under the left hand side joystick? Only the trims on the right hand joystick should be adjustable on these transmitters.
