Need help HL 1/16 S&S Snow Leopard rear lights
Hello gents.
new to this.
Got myself a HL Snow leopard, took out the non smoke board an put in a RX 13. Where do you solder the wires for the rear lights on the board?
new to this.
RE: Need help HL 1/16 S&S Snow Leopard rear lights
try here for a wiring diagram: http://members.iinet.net.au/~wackywheelz/t34/-2nd pic down.
The empty socket is where the rear lights plug in - neg wire is to the right, pos to the left. you can flip the board over and solder direct to the board.
Hope this helps,
Mart
Hope this helps,
Mart
NY
I'm sure you're well aware of this and have done it already, but just in case you haven't , it's worth checking the LEDs' polarity. Might even have been wired the wrong way round at the factory.
I'm having trouble with mine whereby they work individually, but not if I try both at once - I've tried heating the connections to remove the posibility of a dry joint but no dice...
come on guys there must be some one out there with a pershing with a 13 board in it. can any one take a photo of the board showing the rear lights.
Starskey.
Starskey.
CA
ORIGINAL: starskey
Starskey.
Starskey.
Gary
