soviet green??
Old 07-07-2009 | 11:41 AM
Default soviet green??
anyone have a good mix for soveit green? prefably with tamiyas range
im thinking of painting my panzer iv as a captured soviet vehicle (Pz.Kpfw IV Ausf. F1. The107th Separate Tank Battalion. Volkhov Front. July 6,1942)
http://www.rkkaww2.armchairgeneral.c..._tanks_img.htm
Old 07-07-2009 | 03:00 PM
My Feedback: (12)
Default RE: soviet green??
Maybe someone who just got a new Tam KV1 would help out here by sharing the color numbers from painting guide.
Old 07-07-2009 | 04:34 PM
ive been pointed in the direction of testors for a soviet green i would still like a tam match as there paints are very cheap compared to testors especilly when it takes about 3-4 jars to cover a decent sized tank
another paint question btw anyone know of a good acylic thinner,aside from tamiyas own? i can only find tams in dinky bottles
Old 07-07-2009 | 05:48 PM
You can use straight water to dilute Tamiya acrylic paints. you dont have too use thier fancy thinner, witch is almost all alcohol anyway. And why does it take 3 or 4 jars of paint to paint one tank. I usually get atleast 3 paint jobs from on 3/4 once jar of Tamiya paint. I allways airbrush though. I could see using more paint if your use an actuall paint brush, but that still sounds like a lot of paint.
Old 07-07-2009 | 07:31 PM
wouldnt using water as a thinner effect the adhesion of the paint?
bit of an exageration in amounts [sm=red_smile.gif]i used between 2-1.5 jars for my jag and most of that ended up everwere else in tests and for this job i only had one jar on my airbrush so i had to pour out the paint a clean to change color i will order some more airbrush jars before my next paint job i like to have 3 jars of paint for the larger area just to cover my ass as im new to airbrushing
if tam thinner is mostly a alcohol would medical alcohol work?
Old 07-07-2009 | 07:58 PM
Perry S.'s Avatar
Here is one I painted with Krylon camo from the local autoparts store. Standard spray can. Adheres excellent to the red oxide primer they sell as well. Save a tone of money. I'm tired of spending $30 for Tamiya paints for one tank.
Perry
ID:	1231658   Click image for larger version
ID:	1231659   Click image for larger version
Old 07-07-2009 | 09:00 PM
killick64's Avatar
Go to missing-lynx.com and hit the "Search" button. Selet the "network54" option and type Russian Green into the box. Lots of ideas!
Old 07-08-2009 | 07:29 AM
Soviet green is people!!
Old 07-08-2009 | 01:54 PM
Panther F's Avatar
ORIGINAL: patmcf79
Ummm, you mean Soylent Green. [sm=lol.gif]
Old 07-09-2009 | 10:43 AM
I was wondering how long it would take for someone to get that.
Old 07-09-2009 | 11:09 AM
Panther F's Avatar
I don't think everyone here is old enough to have seen that movie.
Old 07-09-2009 | 11:34 AM
kclank's Avatar
I have had good luck mixing Tamiya Russian Black-Green with Tamiya Panzer dark Yellow. Do not know the numbers since i am away from home at the moment.
Old 07-09-2009 | 11:44 AM
i had a liitle jar of pactra soviet green i forgot i had i found that tamiya feild grey with a drop of flat green are a good match for the pactra soviet green
Old 07-10-2009 | 12:30 AM
Guys, guys...
Acrylics? Dollar Stores or Michaels. They often have a large selection, and a 2oz jar is a buck (or no more than 2.69 at Michaels) and diluted can be run thru an airbrush with ease.
Never mind that it says for fabrics or whatever, acrylic paint is acrylic paint. And if you're mixing colors... its MUCH cheaper.
sniggering at people ignoring the obvious sources...
WhiteWolf
