Transition 'bridge' for tanks.
Hey all,
I need a convenient way to get my Panther from manuvers in the front yard via the driveway to my deck. Lifting it from the deck to the driveway was becoming a PITA, so I came up with this bridge. It's sort of a cross between a bridge and a ramp and is similar to common deck bridges used everywhere by the railroads. I couldn't get the deck as low and wide as I wanted it because of the intended location so this will have to do. The 'girders' are machined from poplar and rest is 3/16" luan ply. It's just over 4' long and about 11 1/2" wide. Thanks for peekin'.
Cheers, BOb
Cheers, BOb
CA
RE: Transition 'bridge' for tanks.
Very Cool Bob, thanks for sharing that will work well for a battle field too,, you can get stuck if you don't drive it right!
The Blitz
Looks awesome! You wouldn't happened to have put together a set of drawings with any dimensions for plans would you? It could be widened to be a universal bridge that fits all of the tanks.
ORIGINAL: philipat
Cheers, Bob
Here are some additional photos and dimensions that can be used to build your own transition ramp or bridge. Pic #1 shows the details from one end. This bridge is built from the inside out. I’m going to give the inside dimensions as they are the most relevant. The thickness of the stock used will determine what the outside dimensions become. I think the subsequent photos make it fairly clear where adjustments will need to be made to accommodate the outside dimensions. If not, I'll try to help.
The length is 50". The inside width is 9 ½”, allowing ¼” on each side of the Panther’s tracks. The tread or decks are 2” wide. The decks are 1/8” luan plywood nailed to 1/2 “ X 1 ½” poplar sides forming an ‘L’. The cross ‘beams’ are 5/8”X ¾” poplar milled to a ‘T’ shape and nailed on 5” centers to the treads… see pic #2. The pads on each end are ¼” poplar milled on the underside at the appropriate approach angle, using a rasp. Make your two ‘L’s first forming the basic structure then glue & nail the beams to it. A brad gun is your friend here, but small screws will work fine also, if you don’t have a gun or don’t want to use brads.
After you’ve got the main structure complete, you can add the side supports. These are more 1/8” luan 2 ¾” wide with smaller vertical beams attached on 4” centers roughly as shown in pic 3. The beams can be either machined from a single piece as shown in pic #4 or made from two pieces glued up. You can also use just a single flat piece 1/8” X ½” glued a little closer together to simulate beam reinforcement. The supports are glued to the sides and a cap piece installed across both.
And there you have it. A coat of leftover house paint will form a good base for whatever topcoat you’d like to apply.
Cheers, Bob
Cheers, Bob
