possible soviet green?
Old 09-15-2009 | 08:39 AM
Default possible soviet green?
i have been on this subject before trying to find a good match for soveit green i had a try of the vajello colors and found them hard to use or just plain crap ..whatever im an airbrush novice so i want to stick with whats worked so far-tamiyas range
i had a rummage around some of the static armour forums and found most people use a lightened tamiya xf-67 for ww2 soviet armour any opinions on this?
Old 09-15-2009 | 08:49 AM
ArmChairGeneral's Avatar
Default RE: possible soviet green?
I was looking into this for my KV-1 and this statement sums up what I found:
"The Red Army preferred its armor painted olive green and you won't have problems finding this color in any store. As an alternative, you can use olive drab which looks very similar. Testors Model Master makes a color named "Russian Armor Green" which is almost blue. Most modelers have no idea what that color is and why it's so blue.
Olive green was the predominant color throughout the war but it was impossible to guarantee regular paint shipments to tank factories so the assembly lines often used whatever green was available. If some kind of tractor green was the only paint in stock it was applied without hesitation. Some tanks were not painted at all due to lack of time. A few tanks had a brown camo pattern painted over the olive green but this was applied in the field by the crews and there was no specifications describing it. If you want to try it your guess is as good as anybody's."
Old 09-15-2009 | 09:29 AM
ok then[sm=spinnyeyes.gif]
Old 09-15-2009 | 09:39 AM
Panther F's Avatar
According to Steve Zaloga, he is critical of a trend of modellers using bright greens for Soviet Armor and believed that the shades were dark green, not medium green.
So, I would suggest looking into MM 34079 dark green. At least make the shade much more different than your 'other' dark greens and olive drabs.
HTH
- Jeff
