Schurzen for Stug III
CA
Anyone seen the new schurzen for the Stug III from tank-modelbau.de? Made of polystyrene. I like this product, except it appears that the bracket supports the schurzen through a small rectangular hole in the plates. Is that really correct?
RE: Schurzen for Stug III
Anyone know what is the actual thickness of these? They have no specs on the website and they do look nice.
In real life they were about 4 MM to 6 MM or a 1/4 inch.
- Jeff
- Jeff
Cheap Tank,
Your side skirts look pretty awesome. You should feel proud of the job you did. What did you make the supporrts, rails and skirts out of. great job to all.
Jim
Jim
VA
it is all brass 1/8 angle and flat bar solderd together and bolted on with 1/16 bolts. i have built them with plastic and aluminum but they are to lite to hang rite and break to easy.
