Help needed with Asiatam Tiger recoil unit
My Asiatam Tiger recoil unit packed in. Foolishly, I stripped the wiring from the flash/led contact switch, along with the wiring to the elevation motor/servo and recoil motor /servos without taking photos of the wiring lay out.
I would be grateful if any one could post some pictures of the wiring routing from the LED/Flash switch around the back to the servos and the two contacts on the other side
This is the early recoil unit not adapted for the RX-18 board.
Thanks.
Thanks.
