RX18 boards
NL, CANADA
I do not have much knowledge with the RX18 boards, but are they much better than the Heng Long boards in the tanks? Is it better than the stock Heng Long tank's boards?
They are IMO better than the older boards.
The RX was introduced in the Stug III if a remember correctly.
You can check which board you have in your tank by opening it up
NL, CANADA
Yeah I know, but I really like the airsoft too. Do you really have to remove the airsoft system, if you use the RX18 boards. Is there another RX18 board or any kind of aftermarket board that can be use for these HL tanks without taking away the airsoft?
NL, CANADA
Both the airsoft and IR system in one tank? That will work also? Didn't realize that. So both systems can be operated at the same time in one tank?
