Persing engine covers
Hi Chaps
Just ground out the engine covers on the HL pershing and put new ones in
just wondering what i could put in there to make it look better looking or more like an engine?
Anyone got any ideas or should I just leave it as is
Maybe you can make a relief cover just a few milimeters thick of the pershings drivemotor, but that will a lot of work but can be done, you leave it out when you ride your panzer and when you show it in the shelf you put it in
karel
karel
Here's a shot of the engine I did for our museum cut-away. To have an operational RC tank, you won't be able to make it look authentic unless you have a way to mold a 3D thin insert and even at that, I really don't think the end result would look all that good. There's not enough space to build in what you would need. That Torquematic tranny would be a bear to make. In front of it, on both sides of the huge radiator, were two oil coolers with pulleys and 16 fan belts.(under that flat armor plate). Unless you are making a static display, I'd leave the engine/tranny grilles closed. If you could get hold of a static WSN T-34, it may be possible to use some parts that do look "somewhat similar", but... My engine was made from a block of balsa and some 1;35 car engine parts. Not exact, but pretty close for the display I needed in a hurry. Opening one set on one side and making a hinge would be great for installing the on-off switch. My M-46 is set up like that. Hope this helps.
Hi
I used two upper hulls, a dremel, files, kraft knife and track pins.
Cut the hatches out of the other hull, ground down and drilled holes in the hinges with the dremel.
Then cut out the holes on the tank, ground off the excess, drilled through the pivit with the dremel.
Tidied it all up with the files, all nice and neat
cut down the track pins to size and slipped them in.
the track pins have a rough end so they stay in.
Get yourself an 1mm drill bit it's great for all kinds of things.
some great ideas chaps
Jon
Jon
Hi
Have just posted a video on Youtube
Have a look and see what you think
http://www.youtube.com/watch?v=P8GNiUE20UE
That is awesome nice work! I am gonna have to try this. As for the engine maybe print a photo on card stock and attach it to the inside of the hull?
