need help with my mato sherman
Hey all need some advice to my problem, i got a Sherman from mato had to send back waited a few weeks they sent me a new one, other one was DOA. any who, got it back few days ago works great but then after 15 min of use it starts to hesitate only in forward,it gets worse as i use it more but then if i go in reverse it fine only in forward any advice would be great and don't want to gut it like to keeping this one stock thxs sorry guys it forgot to put in that after it sits awhile it fine again but after 15 min it does it. could something be heating up?
RE: need help with my mato sherman
We experienced a similar situation with one of ours and mentioned it in the Review post for the Mato Sherman.
If it's cutting out, like you're losing the signal you have poor solder connections in the radio on the antenna and or right stick. Open the radio and resolder all connections, including the yellow wire to the antenna and try again. Worked for us.
My sherman has the same issues with ALL OF THE SOLDER JOINTS. IF I even touch a wire anywhere the solder joint fails, so a total rework is in order.
I must have the Sherman that was built on a Wednesday. I have had no issues so far save for a loose crystal inside the tank. Seems the Mato Tanks have the same kind of issues out of the box like the Henglongs. No problem though you will have your Sherman working and you won't regret buying it.
[8D]
[8D]
