 Another question...need some input >
Old 12-06-2009 | 06:48 PM
yellowshaker's Avatar
Default Another question...need some input
Guys, I have decided to do a sound upgrade on the hl Tiger 1. I had removed the stock speaker and installed 2 2" 4 ohm speakers to try them out.the sound is much better, but I know to make it sound realistic I need a sound system upgrade with electronics.I saw the post about someone adding the CD Thunder 1 system and it sounds pretty good for the money.i'm not sure I want to go Elmod just yet. My questions are simple.
1) Can you still retain the start up and shut don sounds and the smoke unit?
2) I have 3 battery packs and It seems a very tight fit in the aluminum hull. Can this unit fit inside w/ battery packs.
3) can someone post some pictures of the unit installed and complete?
4) If I use this system, an I possibly add a battle system later and keep this unit installed?
thanks as always to you guys for any help.
5) Can this system still use the machine gun and cannon sounds or are they eliminated?</p>
Old 12-06-2009 | 08:32 PM
torpedochief's Avatar
Default RE: Another question...need some input
Make your life much easier and visit Blitz at RCTANKWARS.com . If you want all that stuff why fight. With the ElMod, you can have your tank do everything but make yogurt and I think that mod is coming out
Sound Blaster III is the way to go, for us upgrade newbies. Me included.
Don
Old 12-06-2009 | 09:03 PM
I spoke to Phil today actually. I know the Elmod is a good setup but I am thinking a bit low budget for right now on this tank. I do have another tank in the works that I plan to use El mod in.
I'm just wondering how much someone can tell me about the CD setup
