Gearbox Differences??
Old 12-12-2009 | 10:12 AM
pcsguy88's Avatar
Default Gearbox Differences??
I recently got an HL KV-1 with the Asiatam hull. The stock sprockets require a long axle box, but the Asiatam sprockets require a short axle. I swapped axles on the standard metal boxes and it worked perfectly, but I want some steel 3:1 boxes. I put my Panzer III box in and see that the bolt pattern matches and axle sticks out the correct amount, but I am not sure the differences since one is a puller and one is a pusher. Are the motors wired differently between the boxes? Since the PIII boxes will be sitting in there backwards, will this make them sync up with the transmitter controls?
Old 12-12-2009 | 11:59 AM
swathdiver's Avatar
Default RE: Gearbox Differences??
You'll have to reverse the wiring. Same thing we had to do with swapping TK-RX13 boards between Tigers and Pershings in the days before connectors.
Old 12-12-2009 | 07:05 PM
pcsguy88's Avatar
Thanks Swath, I was thinking that was the worse case scenerio. They are officially on there way.
