Now this is interesting
Old 06-01-2010 | 07:31 PM
torpedochief's Avatar
Default Now this is interesting
I found this on a site. Looks great. Does anyone have any idea if any were used in the field?
From July to September 1942, MAN produced two prototypes, only one of which was fitted with a turret. These were extensively tested and proved prone to many technical problems. At the same time, a first order for 1,000 tanks was placed, with the first tank expected in early 1943. In late 1942, a small pre-production series of 20 tanks was ordered. This was the Null-Serie, or Zero Series. Those 20 tanks were designated Panzerkampfwagen V Panther Ausfuehrung A and were technically different from later Ausf A production models. All were lightly armored (with 60mm frontal armor) and armed with the early version of the 75mm KwK 42 L/70 gun. This gun had a single-chamber muzzle brake from the 75mm KwK 40 L/43 gun and was mounted in a turret that featured a drum cupola that bulged the turret on the left side. A 650hp Maybach HL 210 P 45 engine of 21 liters (1,280 cubic inches] displacement powered them. Interesting conversion was Ausf D1 (some sources state that it was an early model Bergepanther) fitted with bolted on PzKpfw IV Ausf H’s turret (that could not be traversed), which served as a command tank of schwere Heeres Panzerjager Abteilung 653 on the Eastern Front in early/mid of 1944. The same unit used other early model Bergepanther that was mounted with 20mm Flakvierling anti-aircraft gun and Flakpanzer T-34(r).
Old 06-01-2010 | 07:34 PM
bigskydude's Avatar
Default RE: Now this is interesting
I forget the details but I know it was used on the russian front..If I recall the turret couldn't rotate(probably too many issues with the turret-ring set-up)), it belonged to a unit that was famous for piecing together weird combinations like this..a few of the hardcore guys here will probably be able to tell you everything about it...
The Combat history of 653 says it was a 'recovery' Panther with a Pz IV turret bolted in place and not able to rotate.
Old 06-01-2010 | 07:55 PM
Here is some thing
http://resolved.members.tripod.com/~...r/panthp4.html
http://www.achtungpanzer.com/panzerk...71.htm#panther
Jimmy
Old 06-01-2010 | 08:17 PM
Rats Darn Darn Darn!
Right when I decide to give building a rest. This baby is just too cool. Arggggggggg!
Old 06-01-2010 | 08:33 PM
Yes I was thinking of doing one of these two years ago now with the HL Panther out you could use the lower hull from that and a turret from a HL Panzer IV .
Jimmy
