KV-1 Tracks
Just received my Mato KV-1 tracks. They are very tight. They have 89 links. Is that normal? I don't have any other tracks to compare. I'd just add one of the extra links, but they only came with the two pins needed to connect the tracks. Thanks for any help.
Check with Phil at http://www.rctankwars.com/ he mite have the adjusters you need now .
If not then check here http://www.welshdragonmodels.co.uk/kv1-76-c.asp for track tension adjusters .
Jimmy
Jimmy
