RE: LOOK AT THIS!!!
You are just awesome fo finding this stuff!
RE: LOOK AT THIS!!!
ORIGINAL: Pzjgr ORIGINAL: yellowshaker I was actually curious aboutthe slack they run in those tracks. I do not currently have a Tamiya KV1, but the ones I have seen have the track tension much tighter. I questioned one guy about it and I was told that they cannot be run very loose like the real ones because they will definitely throw the tracks...Anyone else know about this? I have an SU-152 with the lower hull of a Tamiya KV-1, I ran my tracks lose at last Saturday's battle and had no problems (was the tanks first battle). Duane |
RE: LOOK AT THIS!!!
1 Attachment(s)
FYI: Ran my now sold Tamiya KV-1 with spring loaded return idlers both ways, with loose tracks (+4 links) and tight and it didn't toss its tracks loose, but did run better over various terrain with the slack taken up.
RE: LOOK AT THIS!!!
Ok, so that's 2 that say it will not toss the tracks....I guess I will have to test the waters meself huh? LOL</p> |
RE: LOOK AT THIS!!!
The metal tracks on my SU are slack as hell (due to the weight of the tank over powering the suspension - must fix that at some point!) but I haven't lost a track yet [8D]
http://i1013.photobucket.com/albums/...0/HPIM3341.jpg |
RE: LOOK AT THIS!!!
Thank you for that info...And I LOVE THAT TANK! Where did you buy that kit? Actually it's EL Mod's SU-152 HL conversion kit, they released it for awhile in 2009, they don't make it anymore but supposedly they say their going to re-release the kit. Their site is down now (I don't know why), but before it went down they said their going to re-release this year. And at the RCTankHQ forum they (EL Mod) said they were going to do the KV-85 as well. I bought my conversion kit from a person in Germany, I put in a wanted post at the mmodell.de forum and he sold it to me for $250 I think (it's been awhile). Then I sent it to Daryl Turner to have him install the recoil, elevation and traverse (limited). Duane |
RE: LOOK AT THIS!!!
Love your SU-152 Ex_Pat_Tanker :D
Where did you get the metal tracks from? I eventually want to switch all my tanks to metal tracks. Duane |
RE: LOOK AT THIS!!!
Oh man, now you guys are killing me! Does everyone have one of these things in the armory? Everyone except me? LOL
I have been banned from rctankhq for answering a question on where to buy a part. So it seems I will have to live without the privelidge of searching Nev's elite forum.:eek: Anywho, I have to get me one of those there kits! |
RE: LOOK AT THIS!!!
1 Attachment(s)
Hi Joe,
As you know I sold my KV 1 to Wayne who fought it with that wonderful winter camo job at our NEAD winter battleday. The slack depends on you driving/fighting style. Mine was too lose and the sprockets slipped on the slack tracks in Texas. I tightened them up a little more and had no issues after that. Wayne ran very well in the snow with the KV and I just love the way that it sounds. I still want to get a Panzer IV this spring. That IS looks neat as does the SU. Bob |
RE: LOOK AT THIS!!!
They're asiatam tracks - I got them from RCCommand. They are much better than the Mato ones, and don't suffer from the drive sprocket teeth misalignment problem.
You can also use standard length drive axle gearboxes, not the Panther/KV/Pershing/M41 version that the Mato sprockets require. |
RE: LOOK AT THIS!!!
Mart, does the Su152 kit has elevationa nd recoil or is that added in during the build?
RE: LOOK AT THIS!!!
The gun assembly is set up for recoil out of the box, all it needs is a little grease ;) - I used a Tamiya Pershing unit, the KT one has too long of a stroke.
The mount for the gun is suitable for elevation and traverse out of the box - you just need to figure out how to make it happen. I used a couple of HL Stug elevation motors and some hacked up sheet Aluminium to hold it all together: http://i1013.photobucket.com/albums/...d/HPIM3297.jpg http://i1013.photobucket.com/albums/...d/HPIM3303.jpg http://i1013.photobucket.com/albums/...d/HPIM3305.jpg That lot doesn't show the traverse to well, but its basically the same principal as my JP IV build - which I think is a better way of doing things to be honest - mount both motors off to the side out of the way of the gun, and put the IT emitter over the barrel rather than to one side, so it doesn't limit the traverse on one side like I did with the SU... HTH, Mart EDIT: Found some pics of the gun cradle: It screws into the turret roof (definitely the way to go), with 2 additional support/end stop screws. The cradle ends in a fork shape to engage the back of the gun (2nd pic) with slotted holes to allow movement http://i1013.photobucket.com/albums/...d/HPIM2877.jpg http://i1013.photobucket.com/albums/...d/HPIM2875.jpg |
RE: LOOK AT THIS!!!
That looks liek a nice set-up to me. I am lookign forward to building one of those.
RE: LOOK AT THIS!!!
Invest in an M3 tap tool if you manage to get your hands on a kit - this is invaluable for threading the resin parts to accept the kits screws. Forcing the screws in on their own will end in tears...
The wire they supply for the hand rails doesn't fit thru the eyelets, and they are too small and too hard to drill by hand - so I cheated and used thinner (and tougher!) piano wire for the rails... if you use the stencils supplied for the markings! I have yet to find a white paint that didn't bleed under them - so hold on to the parts that you peel away because after you apply the white paint, you will need to go back and mask off the numbers and blow over them with the base paint to tidy up... HTH, |
RE: LOOK AT THIS!!!
Very nice pictures and some great build tips! If you have the chance and are willing, I woul dlove any other pictures you could either post or email to me. I know I will end up with one of these at some point, so info is a must have for it. I was wodnering how you set up that gun traverse and elevation on those kits. Very nice!!!
RE: LOOK AT THIS!!!
The build thread is here:
http://www.rctankregiment.com/forum/...Asiatam-SU-152 And pretty much every picture of the build is 'available seperately' here: http://s1013.photobucket.com/albums/af252/Ex_Pat_Tanker/SU-152%20Build/#!cpZZ1QQtppZZ36 Hope it helps, |
RE: LOOK AT THIS!!!
You're the best brother! thanks for the links and all the info!
RE: LOOK AT THIS!!!
Duane, your SU is georgeous...I was impressed at the battle, what a monster of a cannon !!
RE: LOOK AT THIS!!!
ORIGINAL: nascardad88 Duane, your SU is georgeous...I was impressed at the battle, what a monster of a cannon !! Thanks Joseph. It's one of my favorite tanks, just have to learn how to battle with it and be a team player (not go off on my own). :D |
RE: LOOK AT THIS!!!
Well, I am sure that thing stands out from the crowd!:D
| All times are GMT -8. The time now is 03:59 PM. |
