Help
I need help, can anybody show me how to wire the asintam recoil unit, I know somebody had to do it first, HA! Thanks
Mergen |
RE: Help
Its the yellow,red,and green wires. Thanks.
Mergen |
RE: Help
I guess none of you people have these in your tank
RE: Help
1 Attachment(s)
The basics of recoil wiring are the same for any motoriized unit. You have a motor, contact switch, power supply feed, and a trigger wire. Trigger wire, and wire feed through contact switch are negative. I hope this helps
RE: Help
It's been a while since I hooked up mine in the P3, but I believe the three wires hook to the small circuit board with 3 contacts on each side.
The small circuit card is where the stock turret wiring is attached. Additionally there should be a black ground wire on the unit to splice into the power ground. I hope this helps. |
RE: Help
The video instructions are available here - http://www.tankzone.co.uk/avi/recoil_pz34.DAT. The file is a Windows Media Player video file.
RE: Help
Thans for that but instructions are for the Tamia and not for the Asin Tam. Ive got the EL-MOD I'm trying to hook up to, Why is every thing in German.
Gary |
RE: Help
Becuase El-Mod is a German company.
RE: Help
Don't you think sence they sell alot of thier stuff in the US that could also put instruction in english.
RE: Help
1 Attachment(s)
Hang On. Here you go. This should help.
This is from the EL-Mod sight |
RE: Help
Thanks I'll try this.
| All times are GMT -8. The time now is 09:28 PM. |
