RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Configuring a Tank with DX6 and BR6000 (https://www.rcuniverse.com/forum/rc-tanks-369/10426862-configuring-tank-dx6-br6000.html)
ksoc 04-03-2011 04:36 PM
RE: Configuring a Tank with DX6 and BR6000
About the steering trim issue. Not clear if you adjusted the steering trim on the DMD itself?
It is next to the RESET button. Labeled RUDD. Next to it is the M.GUN adjustment.
The light are a function of having all the trims set in the correct position - don't remember the exact sequence off the top of my head. Little tougher on a digital radio.
dlobmwm3 04-04-2011 06:06 AM
Thanks Kevin. I will try the adjustment on the DMD tonight. I COMPLETELY forgot about this. Thanks.
dlobmwm3 04-04-2011 04:53 PM
ORIGINAL: ksoc
THAT WORKED KEVIN!!!!http://www.rcuniverse.com/forum/js/f...eeth_smile.gifYOU ARE DA MAN!!!! Thank you for helping out everyone. Now, 2 more items. I need to move the guns to button/switches on my other post.
<br type="_moz" />
ksoc 04-04-2011 10:08 PM
Id got a DX6 and DX6i. Got the Main gun to fire, but it has been a while so I don't recall exactly how. I DID reference the posts on RCU. One thing I do remember it is important where which direction some of the other switches are in, so if the switch you are working on isn't responding, try flipping some of the others. Will try to did out my radio and figure out what I did...... Once you figure it out remember to label write it down - unlike me :)
Good luck
