RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Simulated lamps on models (https://www.rcuniverse.com/forum/rc-tanks-369/10629799-simulated-lamps-models.html)
Tanque 07-19-2011 09:53 PM
What is the consensus on what is better to simulate headlights on tanks, WWII vintage.
Clearly bright white/ blue leds aren't correct as I'd imagine the lamps of the era tended to be
yellowish. Yellow leds would be too yellow.
So does that leave grain of wheat bulbs? I believe that's what Tamiya used in their Pershing and probably
others.
I read parts of a thread here where the author mentioned 1.8mm yellow leds but still they see too yellow
then I haven't tried them.
What is everyone's thoughts on this?
Jerry
yellowshaker 07-19-2011 10:11 PM
RE: Simulated lamps on models
I found a site for rairoad stuff that sells the perfect LED for this. 1.8mm warm white and they will work on up to 9v.
www.modeltrainsoftware.com. I use them in alot of my builds now.
maintcoder 07-20-2011 04:39 AM
I am giving these a try - Grain of sand bulbs with a suitable resistor.
<font size="-1"><font size="-1">http://www3.towerhobbies.com/cgi-bin/WTI0095P?FVSEARCH=L5AJ6606+&amp;search=Go</font></font>
Spitvalve 07-20-2011 07:59 AM
On my HL KV-1, I removed the LED, hollowed out the headlight housing, ground off the tip of the LED and reinstalled it in the housing. There was now clearance to fit a headlight lens over it. Before doing that I gave the LED and inner headlight a coat of yellow acrylic followed by coats of silver acrylic until it was the muted yellowy-off white I wanted. Looks better than the hideous glowing nipple of the original HL design. Sorry no pics, image loader seems kaput on this board...
Mike.
strmnd54 07-20-2011 08:00 AM
1 Attachment(s)
Hi guys !!! I bought some 3 mm high intensity leds a while ago for my smoking gun project ...Here's a couple of pics. to compare the shades...( I'm using a 240 Ohms 1/4 Watts resistors ) ...
Here's the link for the data sheet for the leds ...<a target="_blank" href="http://pdf1.alldatasheet.com/datasheet-pdf/view/282990/BETLUX/BL-L304UYC.html">pdf1.alldatasheet.com/datasheet-pdf/view/282990/BETLUX/BL-L304UYC.html
<br type="_moz" /></a>
smittyrob 07-20-2011 08:25 AM
I use "yellowglo white" leds. Simulates incandescent bulbs. Not too white not too yellow, looks like old headlights.
strmnd54 07-20-2011 09:34 AM
Anybody knows if " Yellowglo White " and " Warm White " are 2 different colors ; or are they 2 different names for the same color ?????
Pah co chu puk 07-20-2011 11:37 AM
I went the cheap route, I put some yellow Teflon plumbers tape over the LED inside the light housing.  It is kind'a yellow, but it was already paid for.
Rex Ross 07-20-2011 12:30 PM
Jerry......
My solution is simple, hope this helps.........All of the lamps on my WWII tanks have been shot out, damaged, stolen or taken off.
Problem solved.
Panther F 07-20-2011 12:45 PM
Yep ... don't even install them on mine.
- Jeff
strmnd54 07-20-2011 12:48 PM
The warm white leds look pretty good to me according to those pictures ....www.google.ca/search
WhiteWolf McBride 07-20-2011 01:03 PM
Rex:
That or hide 'em under a few German tin pots (helmets) like they used for lamp shades in quite a few or the WW2 movies (Patton in partiucular, for lighting his map-boards)
But if ya gotta choose... Tamiya ~does~ make a transparent yellow paint for lenses, as well as a red. Found that out a while back when working on my 4x4 Mountaineer (and his cousins) Then there is the simple idea of buying some colored overhead cels from an art store or even gift-wrap cellophane from the old stand-by, the dollar store!
And now that I think about it, any yellow overhead marker or highlighter should do for 'painting' the styrene. If ya got kids, try the markers first. Test it on a bit of sprue!
WhiteWolf
PS: And gently 'frosting' the inside of the lens helps diffuse the glow from a point to a full-lens glow. The Easy-Off/Mean-Green cleaners will frost the clear plastic... though a pit of coarse polishing compound on a Q-tip would do as good (if ya got any) In a pinch, Conet or any of those other 'grit' cleaning products do for a coarse polisher, and old toothpaste for a fine one (long as ya don't mind the lenses smelling minty-fresh! ;-) )
Spitvalve 07-20-2011 01:35 PM
1 Attachment(s)
Modified headlight on my KV-1 with yellow and silver acrylics for dulling. Excuse the silver on the headlight bezeltank is still undergoing final paint and weathering.
Mike.
Tanque 07-20-2011 06:37 PM
Rex as always your solutions are out of the box.... priceless...
Thanks to everyone for their replies.
While I like the warn white led idea I have a dozen or so 3-4v grain of wheat bulbs I purchased
at the old San Antonio Hobby shop years ago before they closed. A sorely missed shop.
I'll use those for this little project and see how they work; when they burn out I'll use Rex's
ploy...
Jerry
