call for help to the 'electronics' on this board for a Wirbelwind project
1 Attachment(s)
<p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;">Hi chaps, i need help from the ‘electronically’ talented people in this board<o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;">I’m immersed in a new project, a Wirbelwind based in an old HL PzIV chassis. I want to hold the costs to a minimum, and I would like to use the HL electronics, the HL remote and a beier sound card for the sounds. I already own them, so I do not have to expend money in this area. <o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;">The alternative could be the future Taipan board, or the RC2HL solution, but the shipping costs from OZ to Spain are ‘devastating’…<o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;">Without taking into account the use of recoiling, if possible at all, I would like to know what you think about my idea, if it’s feasible or do you have any other way to do it… so:<o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;">
- imagine a turret less HL PzIV, with the Wirbelwind one installed and with the flakvierling inside<o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;">- imagine that no servos would be used for elevation of the guns or rotating the turret, only engines.<o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;">- the turret rotation would be the same as any other HL<o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;"><o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;">The standard HL ‘8 wires’ group of cables going from the RX18 to the upper hull is distributed in this way:<o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;"><o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="font-size: 10pt; font-family: Arial, sans-serif; background-position: initial initial; background-repeat: initial initial;">pin 1 (<span style="color: rgb(0, 0, 0);">black</span>)<span class="apple-converted-space"></span></span>-<span class="apple-converted-space">negative turret rotation (3.8V - 4.0V)</span><span lang="EN-US" style="font-size: 10pt; font-family: Arial, sans-serif;"> <span style="background-position: initial initial; background-repeat: initial initial;">pin 2 (</span></span><span lang="EN-US" style="font-size: 10pt; font-family: Arial, sans-serif; color: red; background-position: initial initial; background-repeat: initial initial;">red<span lang="EN-US" style="font-size: 10pt; color: black; background-position: initial initial; background-repeat: initial initial;">)<span class="apple-converted-space"></span></span><span style="color: rgb(0, 0, 0);">+<span class="apple-converted-space">positive turret rotation</span></span><span lang="EN-US" style="font-size: 10pt; color: black;"> <span style="background-position: initial initial; background-repeat: initial initial;">pin 3 (<span style="color: rgb(0, 0, 255);">blue</span>)<span class="apple-converted-space"></span>-<span class="apple-converted-space">negative motor gun fire recoil airsoft (4V)</span></span> <span style="background-position: initial initial; background-repeat: initial initial;">pin 4 (<span style="color: rgb(255, 255, 0);">yellow</span>)<span class="apple-converted-space"></span>-<span class="apple-converted-space">negative motor gun elevation (7.2V)</span></span> <span style="background-position: initial initial; background-repeat: initial initial;">pin 5 (</span></span><span class="apple-converted-space"><span lang="EN-US" style="font-size: 10pt; color: rgb(136, 0, 0); background-position: initial initial; background-repeat: initial initial;">brown</span><span lang="EN-US" style="font-size: 10pt; color: black; background-position: initial initial; background-repeat: initial initial;">)<span class="apple-converted-space"></span></span><span style="color: rgb(0, 0, 0);">+<span class="apple-converted-space">positive common to elevation and gun engines</span></span><span lang="EN-US" style="font-size: 10pt; color: black;"> <span style="background-position: initial initial; background-repeat: initial initial;">pin 6 (</span></span><span lang="EN-US" style="font-size: 10pt; color: rgb(0, 187, 0); background-position: initial initial; background-repeat: initial initial;">green<span lang="EN-US" style="font-size: 10pt; color: black; background-position: initial initial; background-repeat: initial initial;">)<span class="apple-converted-space"></span></span><span style="color: rgb(0, 0, 0);">+<span class="apple-converted-space">positive common to light and MG shooting</span></span><span lang="EN-US" style="font-size: 10pt; color: black;"> <span style="background-position: initial initial; background-repeat: initial initial;">pin 7 (white) - negative light <span style="background-position: initial initial; background-repeat: initial initial;">pin 8 (<span style="color: rgb(255, 153, 0);">orange</span>)<span class="apple-converted-space"></span>-<span class="apple-converted-space">negative MG</span> shooting<o:p></o:p></span></span></span></span></span></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="font-size: 10pt; font-family: Arial, sans-serif; background-position: initial initial; background-repeat: initial initial;"><o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="font-size: 10pt; font-family: Arial, sans-serif; background-position: initial initial; background-repeat: initial initial;">so then:<o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="font-size: 10pt; font-family: Arial, sans-serif; background-position: initial initial; background-repeat: initial initial;"><o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="font-size: 10pt; font-family: Arial, sans-serif; background-position: initial initial; background-repeat: initial initial;">- there would be no tank gun or recoil or fire system, then the pin 3 (blue) would be free<o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="font-size: 10pt; font-family: Arial, sans-serif; background-position: initial initial; background-repeat: initial initial;">- it would be possible to use the pins 6 and 8 for MG shooting to fire the flakvierling LEDs with the K button<o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="font-size: 10pt; font-family: Arial, sans-serif; background-position: initial initial; background-repeat: initial initial;">- on the remote, stick down controls the tank gun elevation, but on a cyclic way, the engine always runs in the same direction (no polarity reverse)<o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="font-size: 10pt; font-family: Arial, sans-serif; background-position: initial initial; background-repeat: initial initial;">- on the remote, stick up controls the tank gun firing</span><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;"><o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;"><o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;">Well, have I said any incorrect?<o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;"><o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;">Now, the possible solution to have elevation and depression of the flakvierling , up or down, without the cyclic thing, and is here where I need your thoughts and advice!<o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;"><o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;">Could be possible, to use the ‘liberated’ pin 3 (blue) (remember, no tank gun to be fired) to make the elevation engine to turn in the opposite way? <o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;">With some electronic component? A polarity inverter? A relay? An H bridge?...?<o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="ES-TRAD" style="background-position: initial initial; background-repeat: initial initial;"><o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;">If this i just said could be doable, then the guns could be fired with the remote’s K button, the remote’s sticks down and up to control the flak elevation…<o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;"><o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;">What do you think? Do you have any other idea to achieve what I want?<o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;"><o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;">Best regards and thank you very much!<o:p></o:p></span></p><p class="MsoNoSpacing"><span lang="EN-US" style="background-position: initial initial; background-repeat: initial initial;"><o:p></o:p></span></p><p class="MsoNormal"><span lang="EN-US" style="font-size: 10pt; line-height: 115%; font-family: Arial, sans-serif;"> <![if !supportLineBreakNewLine]> <![endif]><span lang="EN-US"><o:p></o:p></span></span></p> |
RE: call for help to the 'electronics' on this board for a Wirbelwind project
dan can help you for that, he made a set for my upcomoing wirbelwind from the tamiya P4 ausf J
YHR is his name here he will shorely help you out Dan i have to contact you for that, not forgotten will soon email you karel<br type="_moz" /> |
I hae no experience with the Beier sound card. You could make this work with a DBC3 as it would allow you to use a servo for the gun elevation. Without that though you are kind of hopped if you just stick with the RX 18.
Cheers Dan |
hi all!
thanks for your comments Dan, the main problem is that i would try to use what i already have. Buying a DBC3 also requires a benedini, a receiver (maybe ESCs too) and a decent remote, same case if i buy the RC2HL or the Taipan (when available). One will trevel from north america, the other from oz ... is possible that have to fall in changing my mind and be force to go one way or the other, but firts i would like to be sure that what i've thought is doable, or not... looking for threads talking about electronics, servos, and the like, i saw replies from different memebers who have-it seems to me- a high level in this matter, and here is may hope, that any of them could say something... Karel, do you have any link to your project? i would like to follow the work of others walking my same path! best regards<br type="_moz" /> |
it is still unstarted am busy on a couple of 1/10 defender MP version etc and two 1/16 halftracks 251/1 ausf B and D
the link is here so far : on BTB :forum.battletanksbelgie.be/viewtopic.php i let you know when it starts ORIGINAL: Jussek hi all! thanks for your comments Dan, the main problem is that i would try to use what i already have. Buying a DBC3 also requires a benedini, a receiver (maybe ESCs too) and a decent remote, same case if i buy the RC2HL or the Taipan (when available). One will trevel from north america, the other from oz ... is possible that have to fall in changing my mind and be force to go one way or the other, but firts i would like to be sure that what i've thought is doable, or not... looking for threads talking about electronics, servos, and the like, i saw replies from different memebers who have-it seems to me- a high level in this matter, and here is may hope, that any of them could say something... Karel, do you have any link to your project? i would like to follow the work of others walking my same path! best regards<br type="_moz" /> |
go for it Karel! ;-)
have i translated it corretly your link?? are you saying there that you will use a RX18 + DBC3 + benedini? also, i think that the soundfiles are a special mod by YHR and are already done? i'm openminded, and i want to know what alternatives could be used in this project! i would like to be able to customize the sounds, it's a feature i love in the Beier cards. Dan, could you explain to an electro-illiterate like me what could be done with your combo in order to run a wirbelwind? the project i'm working on will use 3 servos, one for rotation, one for elevation and the other for the gun's recoil (yes, i've a colleague in a spanish forum who is SURE it could be done!) if this is a viable option, then we could talk ;-) any idea would be wellcome! best regards |
yes dan have the soundfiles allready at disposal , the pitty is i converted a tamiya FO Pzkfz IV ausf J , very expensive kit but very well made too ... but for now the tamiya is still in the box but i have him at my collection ... no worry
the downpoint i have to skip the tamiya mf module from the P4<br type="_moz" /> |
thank you karel
An RX 18 DBC/benedini combo would be able to do all this. For rotation you would use the RX 18, elevation could be controlled with a servo, and the recoil could be built to have a negative pulse trigger it. I have the sound files built for the Benedini for this.
hello Dan
thanks for your reply so, the Santa list could be: - RX18 (i have it already) - HL turret turn device (i have it already) - DBCx (x=3?) - benedini TS mini - TBS programming cable - 6ch receiver (wich one?) - 6ch remote(wich one?) - 2 mini/micro servos - anything else? the benedini, will produce ALL the sounds, am i right? how would this combo manage to fire the 4 guns? using the MG instead of the main gun? best regards <br type="_moz" /> |
| All times are GMT -8. The time now is 05:10 PM. |
