RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   DMD or T0-* (https://www.rcuniverse.com/forum/rc-tanks-369/11483480-dmd-t0-%2A.html)
Rustytrax 04-18-2013 01:27 PM
DMD or T0-*
I have tank that can be killed everytime I bench test it, but durring battle it takes a few hits then resets but never accumulates more damage. The apple(s) will indicate hits and the sounds do function.
Is it the DMD or the t0- unit?
ausf 04-18-2013 01:48 PM
RE: DMD or T0-*
Are you positive the two selection switches are correct?
I somehow tripped one once and had the Indestructable Tiger for a while. It took hits but was the RC battlefield equivalent of the energizer bunny. I think I had to go through the set up protocol to correct it afterwards too.
Rustytrax 04-18-2013 02:22 PM
RE: DMD or T0-*
I tried the reset but I never got the light sequence the manual says should happen.
thecommander 04-18-2013 04:27 PM
RE: DMD or T0-*
ORIGINAL: Rustytrax
The MF units handles that function via the apple. Check all the wires for chaffing (especially the TBU) and make sure the apple is secure in the base. That is why the have a metal locking system. Does it display hits on the apple but not record them as damage on the MF unit? One of the safeguards in the TBS is that it cannot give or record hits w/o the apple. If the apple is lights when hit and the wires and connections & wires (Comm cable too) are all good and you have good charged batteries (Helpfull Hint: Low batteries cause the majority of all tank electronic issues) then the MF is the likely culprit. I know you have several Tamiya tanks Troy. Try swapping apples and then swap in another MF. The MF unit numbers do not matter for this purpose. To further isolate the problem is you can also put the suspect units in a good tank to see if the problem in just in one component or more. Call me tonight if you like. I am finishing a Tiger and M26 for customers and will be up late.
Rustytrax 04-18-2013 05:32 PM
RE: DMD or T0-*
I have a pershing MF in the m51t now but bench testing never could duplicated the issue. It only happens during a multi tank fight while moving and shooting. I was just checking to popular opion to see if I replaced the correct item (the expensive one lol)
As fate would have it I'm off to dallas this week and the battle is next weekend.
thecommander 04-18-2013 05:44 PM
RE: DMD or T0-*
1 Attachment(s)
DMDs are usually more costly than MFs. Send it back to Tamiya and advise them this is an intermitant issue. Send them video of the problem if posible.
PS I mailed out Futaba radio parts to you. I will have NIB Futaba 2.4 GHz "tank ready" radios at Brett's. So don't worry if you don't get back in time to install them, I will swap you a tank ready radio for the one you bought from me at Danville. I just got a shipment of 15 Futaba radios in last week. Either way...I got you covered pal.
bowlman 04-18-2013 07:53 PM
RE: DMD or T0-*
Could having MF Unit set for test mode cause this ? .
Jimmy
thecommander 04-18-2013 08:26 PM
RE: DMD or T0-*
ORIGINAL: bowlman
Jimmy
Troy said he already checked the dip switches and ran set-up.
heavyaslead 04-19-2013 06:34 AM
RE: DMD or T0-*
Another thing to be aware of:
Switching apples or plugging and un-plugging apples while the power is still ON can cause some anomolies with hits and firing.
My experience has been with an invulnerable tank that can take hits but never die. I had installed the apple while the power was ON. Shutting down and restarting cured the problem.
heavyaslead 04-19-2013 06:38 AM
RE: DMD or T0-*
I believe HEAT did some glitch resetting trials and replicated a reset if a partial fire signal or partial fire signals from multiple tanks arrive at the detector.
Again registering hits properly is mainly attributed to partial voltage on the battery.
Rustytrax 04-19-2013 06:41 AM
RE: DMD or T0-*
I think I may have damaged the Multi function some time ago when I switched the modes with the power on.
The issue only seems to happen when I'm moving, shooting and taking hits at the same time.
I never install or remove the apple with the power on.
Jeff489 04-19-2013 10:15 AM
RE: DMD or T0-*
Just wondering what MF and DMD combination you are having issues with?
If I recall, a DMD T-08 goes with either the MF-06 (KV and JS tanks) or MF-07(M51) and a DMD T-06 goes with the MF-03 (Pershing).
Rustytrax 04-19-2013 02:16 PM
RE: DMD or T0-*
I had issues with a MF-07 T0-8. I'm switching to all Pershing units since I have a t0-6
Jeff489 04-19-2013 06:22 PM
RE: DMD or T0-*
You might try swapping out the MF you suspect for another one you know is good, just to be sure that's the problem.
