RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   The IBU2 is coming (https://www.rcuniverse.com/forum/rc-tanks-369/11533833-ibu2-coming.html)
scooter_it 06-09-2013 12:00 PM
RE: The IBU2 is coming
http://imageshack.us/a/img546/5635/t...bleadapter.gif
Hi guys,
here it is you can build it using a couple of HL stock cables, obviously this works also with the Impact apple (tested today)
We have addedanew feature : the turret traverse is now proportionalinstead of standard HL on/off turning, this means that you canrotate the turret very slowly ;-)
YHR 06-09-2013 12:39 PM
That's easy enough. I wish El Mod would pass along something like this as well.
How many LED's could the Flasher circuit handle?
scooter_it 06-09-2013 11:45 PM
The flasher port can handle 2 leds series connected in parallel (same as TBU).
The flasher ring (supplied with the IBU) that fit the HL apple is wired the same way.
YHR 06-10-2013 05:39 AM
OK Thanks
heavyaslead 06-10-2013 06:54 AM
Well done! Especially like the programming feature like the Tamiya stick setup.;)
Does this have provision for cannon flash?
AFV432 06-10-2013 10:18 AM
Cheers for that info Scooter ;)
scooter_it 06-10-2013 11:07 AM
ORIGINAL: heavyaslead
Yes, the board have a port for a highpowerflash led
heavyaslead 06-10-2013 12:40 PM
ORIGINAL: scooter_it
Yes, the board have a port for a high power flash led
This would be a nominal 5V LED and not the Tamiya high voltage flash bulb, correct?
scooter_it 06-10-2013 11:16 PM
Yes, a 5 mm. high power white led
B.A.D.A.S.S.Force 06-12-2013 07:22 AM
Ivano, I had a couple questions, possibly off topic, so I sent you a PM rather than post them here in your thread.
When you get the chance please read the PM, if you can answer the questions ... great, if not, that's ok too. http://www.rcuniverse.com/forum/js/f...wink_smile.gif
Thanks!
~ Craig ~
scooter_it 06-13-2013 01:17 AM
Hi Craig,
PM sent ...</p>
scooter_it 06-21-2013 06:31 AM
For those interested :
First and second batch sold out.
Preorder for the third batch open.
PM me for details
Scooter
strmnd54 06-21-2013 06:46 AM
On the specs for the sound, you mentioned:
"<span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255);">- 2 channels sound with 3W/4 Ohm on-board</span>amplifier<span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255);">(replaceable with optional 8W/4 Ohm one)</span><br style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255);" /><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255);">1 Channel dedicated to engine sounds</span><br style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255);" /><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255);">1 Channel dedicated to all other effects, with priority table to play them"
Are those 2 channels pre-mixed inside 1 chip, or will it be possible to tap into the " engine sounds " channel to power an "Acoustic Smoker" for exemple???<br type="_moz" /></span>
Wibblywobbly 06-30-2013 01:30 AM
ORIGINAL: YHR
I asked Thomas about the pin outs, this was what I got
(side facing the front of the tank)
sensor front | sensor right
LED cathode | +5V
GND | GND
+5V | LED cathode
sensor left | sensor rear
I couldn't make sense of it, but if you can, then we should be able to hook up a 5 pin socket to the Elmod IR and use any other apple.
scooter_it 06-30-2013 01:49 AM
Yes it works, i'm using on one of my tanks an Elmod setup with HL and Tamiya apple.
The only thing to take care isto use the "sensor" frontinput.
YHR 06-30-2013 05:25 AM
The only thing to take care is to use the ''sensor'' front input.
Ivano
You would do the hobby another big favor if you could do up a quick schematic of how you have the Elmod using the TBU. I stated this project, had some issues figuring it out and ended up selling my Elmod stuff.
scooter_it 06-30-2013 01:01 PM
Hi guys,
Assuming that you have theElmod cable that connect the CSI card to the Elmod appleand looking at the 8 ways HL style connector the first groupof threewires are :
pink = GND
blue= +5V
green = led kathode
then we have a blank position, after this we have a group offour wires as follow:
orange = left sensor
red = rear sensor
brown = front sensor
black = right sensor
so, what we gonna do now ??? Well we need the pink, blue, green and brown that must be connected this way :
pink(GND) to TBU pin named V0
blue(+5V) to TBU pin named V+
Green(led kathode) to TBU pin namedLED-
Brown(FRONTSENSOR) to TBU pin named IRSIG
the free pin left on the TBUmust be connected to battery+ of the system (Elmod use +5V to supply the leds, Tamiya use 7.2V)
You can find the TBU connectionsimage with description andnamesusing google (type in : Tamiya battle unit connections)
(Sorrythis to avoid claims with image owners).
If not clear drop a line and when i come back to work at the end of the weeki'll make a simple schematic.
Cheers
Ivano
YHR 06-30-2013 02:18 PM
Thanks Ivano
scooter_it 07-02-2013 10:39 PM
Hello,
One of the first customer of the card made apost of his first impression and a couple of video here :
http://ibu2.forumattivo.com/t11-ibu2-first-impression
Cheers
Ivano
borealis 07-03-2013 01:38 AM
From the link above, a new standard way to properly test electronics: :D
http://i35.servimg.com/u/f35/15/16/85/12/sv106911.jpg
And direct link to videos if anyone has problems accessing the IBU2 forum:
http://youtu.be/kYvNcoZLaHY
http://youtu.be/LzVoB594jxo
YHR 07-03-2013 08:28 AM
:DI am looking forward to this, and playing with some sound files.
borealis 07-13-2013 10:39 AM
Finally some official demo video about the IBU2 functions. The tank (M4A3E8 "Thunderbolt VII" Sherman) is by Scooter (I'm just the movie director) and is almost finished.
All functions as per latest firmware
Sound demo:
http://youtu.be/itrl8XYE_jQ
http://youtu.be/IB1_9TU2k0c
http://youtu.be/I2azWwW4agU
ausf 07-13-2013 12:12 PM
Nice.
He may need to add some slack to the flash unit (if there is one). The barrel dip with recoil means something is getting caught and causing unwanted elevation movement.
Buckeye36 07-15-2013 08:37 PM
Hi guys,
pink = GND
blue= +5V
green = led kathode
red = rear sensor
Cheers
Ivano
I'm wanting to make sure I understand this correctly, the free pin of the TBU needs to be connected to a constant 7.2v supply?
scooter_it 07-16-2013 01:04 AM
@ ausf
Yes the servo recoil arm touches the inside of the turret when barrel is up, grrrr i have to open up the tank another time ...
@ Buckeye36
Yes sir, you have perfectly understood
cheers
Ivano</p>
