E-25 Tank
hi
after i have done the work on the E-100,E-75, E-50 Hul now its time to create a E-25 hull. here are a few picturs of the fist cuted prototyp, i will made now the rest drawings based on this hull. http://img5.fotos-hochladen.net/uplo...0d8ywkat65.jpg http://img5.fotos-hochladen.net/uplo...104sewhy9c.jpg http://www.fotos-hochladen.net/uploa...2u1fps3ieh.jpg http://www.fotos-hochladen.net/uploa...p4hjtfdcuk.jpg http://img5.fotos-hochladen.net/uplo...d8xwfpqzg9.jpg cu christian |
Cool! :D
Awesome
moin
thank you. now this projekt goes final. http://img5.fotos-hochladen.net/uplo...u7l96wfjc3.jpg http://www.fotos-hochladen.net/uploa...oa3cjlq52x.jpg http://img5.fotos-hochladen.net/uplo...dovgj37fz8.jpg http://img5.fotos-hochladen.net/uplo...aekzc9sof8.jpg http://img5.fotos-hochladen.net/uplo...x3l4c57ew9.jpg i used standart tamiya kingtiger suspension http://img5.fotos-hochladen.net/uplo...7hgcj9mdsl.jpg the kannon front is still out of ouer jagdpanzer IV projekt but he will get own now. cu christian |
Hi Chris! Would you give us a photo of the inside showing how you mounted the suspension and swing arms?
Thanks, Rudy |
Impressive! MOST Impressive!
hi
thank you guys :-) here comes the picture frome the suspension. http://img5.fotos-hochladen.net/uplo...jfmkc3aueq.jpg cu christian |
Looks easy! So you used Tamiya swing arms and torsion bars correct?
Thanks, Rudy |
hi
yes its the Kingtiger tamiya suspension. but because of this suspension ty i need to modivy the other side roadweel position a bit, thata not scale :-( cu christian |
I luv it!
Gotta put this on my "Wish List"! ;) Jeff |
Any chance to have it using a cheaper suspension system?
hi
hehe thank you :-) mmh, i think i will start working on a HL suspension but this tamiya style suspension cost less than 40 euro. so i think the HL suspension will cost some less but the saved money is it mybe not worth..... not sure cu christian |
Christian:
If the KT roadwheels are so right, but the suspension is a bit 'off' because of the left/right stagger, why not truncate the torsion leaves/bars in the center of the chassis... so that the left/right leaves meet in the middle... and you don't have to stagger the left-right axles? And if the leaves/bars prove to bee to stiff, why not use more flexible ones, or that modded torsion kit from Axel, AFV, or whomever over there makes it? Just thinking... again... (been static way too long...) |
hi
you are right there are alot of posibilitys ;-). wich one my custumer wants is up to him ;-). this layout its just the best situation for the parts you can get from one supliere, if you want to change or mix the suspension parts, you will get more posibilitys. zhere are so many on the market. let me knew wich one you want in your E-25 :-). cu christian cu christan |
moin
Today he get some lidel improfemed :-) http://www.fotos-hochladen.net/uploa...hgy6esawdz.jpg http://img5.fotos-hochladen.net/uplo...qvnzurhl6y.jpg http://www.fotos-hochladen.net/uploa...rozx7d63f8.jpg http://www.fotos-hochladen.net/uploa...ix2nztju57.jpg cu christian |
Hi Chris, When will this be ready to purchase? Also are you able to produce a lower hull for your Panther D/A upper hull kit that can use the Tamiya Panther G suspension parts? Thanks, Rudy
hi
it will be ready in about 2 weeks i think. sure i have alredy the tamiya suspension aviable for this Panther A/D kit http://img5.fotos-hochladen.net/uplo...k18rz56ncb.jpg http://img5.fotos-hochladen.net/uplo...dcs4h58o2l.jpg and for this suspension variant i have a hull too http://img5.fotos-hochladen.net/uplo...b8yknsw7ql.jpg cu christian |
| All times are GMT -8. The time now is 12:57 PM. |
