1/24 Type 90 Tank Problem
Hello.
I hope I posted this to right sub-forum. I have 1/24 Type 90 Tank and it was in the box for a while. Today I took it out and charged battery but tank does not respond. I disassembled it and saw that one wire is broken, and I don't know where to solder it?? Images are too big so I posted links. Tank Tank Circuit board |
Looking at the board I take it that it's a heng long 1/24 tank? I have 1/24 vstanks I would open up and take a look , but most if not all have cable plugs and are not soldered to the board, so if it is Heng Long then I don't think I can be of help, but I'm sure there must be a schematic for it somewhere on the net. Good luck.
Greg |
Yes, it's Heng Long.
thanks That wire is coming from the battery and it is gnd - EDIT: I solved it. I soldered black wire to the switch. http://static.rcgroups.net/forums/at...6-DSCF2831.jpg |
Glad to hear you got it fixed.
Greg |
| All times are GMT -8. The time now is 03:33 PM. |
