RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Clark TK22 Sound Problem (https://www.rcuniverse.com/forum/rc-tanks-369/11618317-clark-tk22-sound-problem.html)
Kampfwagen 06-12-2015 08:51 AM
Hello, I have installed the clark tk 22 in my HL leopard, everything works fine except for the sound it is very low. I am using a decent speaker: visaton 10W with 8 Ohms 150-20000 Hz with a 10K potenciometer however, when I use the volume knob from the HL stock electronics the sounds improves a little bit but not full potential. Any recommendations? Any advice will be appreciated
Thank you!
kizwan 06-12-2015 09:03 AM
I'm think you need an amp to boost the sound when using 8 ohm speaker.
Do your sound volume lower than this?
https://www.youtube.com/watch?v=y9UsVg0-gaw
Kampfwagen 06-12-2015 11:56 AM
Yes definitely less than that! Do you have any recommendation for the amp? and the wiring? thank you very much
kizwan 06-12-2015 01:50 PM
The speaker I'm using in that tank is 4 Ohm 10 Watts speaker & I didn't use amp. I have seen people using from 15 to 35 Watts amp. So, any amp should be good though. You may also need DC converter because all amp I have seen require 12V. There is a guy at facebook that tested many amp. If I can find which one he recommend, I'll post here.
Kampfwagen 06-12-2015 03:21 PM
thank you!
Green Amphibian 06-12-2015 06:35 PM
Battle Armor makes an amp and sells the Benedini sound boards too. I also think Clark is now making an amp also.
Herman
