RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Decent speaker setup (https://www.rcuniverse.com/forum/rc-tanks-369/11623595-decent-speaker-setup.html)
Sky_HawK 11-12-2015 06:18 PM
So I'm messing with adding sound cards to my M1A2, specifically the same ones Dan at Battle Armor used in his tutorial. I thought this would be a fun project to try out myself so I ordered 4 of the cards. Tonight I got their software working and loaded a few M1 sounds I edited. They work as they should, so now I'm searching for a speaker that will give some decent sound and not break the bank. I'll probably wire it all up with the stock HL speaker to get it working and add a better speaker after that using the stock amplifier. Thanks in advance!
yellowshaker 11-12-2015 07:16 PM
You might like these
http://armorcreations.weebly.com/spe...ectronics.html
hiramekisama 11-12-2015 08:29 PM
Those visaton FRS7 are unbelievably loud for their small size.
You can get them here too: http://www.parts-express.com/visaton...4-ohm--292-528
RichJohnson 11-12-2015 09:53 PM
I hooked up a Tamiya Sherman speaker and was blown away on my bendini but had to remove it because its 4 ohm. Dan says the bendini needs an 8 ohm speaker so I got a regular one and am going to mount it in a project box for a baffle box to give it optimum sound.
YHR 11-12-2015 10:22 PM
You will want to get an amp to go along with the 123 electronics sound cards. Visaton and Aura. are the speakers I prefer to use. I also found a bunch of Compaq desktop computer speakers at a wholesaler and they are good as well.
Just remember always go with the biggest speaker you can fit.
Cheers
Sky_HawK 11-13-2015 08:43 AM
Thanks everyone! And should I go with 8ohm or 4ohm? I'm thinking the 4ohm will be the ticket to get a little more sound and the mono amp I'm looking at will push 4-8ohm drivers. It's only 2.5W though.
Sky_HawK 11-13-2015 12:52 PM
Ok, I went ahead and ordered anyways. Got a couple 2.5W Mono Amps with adjustable gain and two Visaton FRS7-4 drivers. I've my sounds working off their triggers as I wanted, only one left to do is the turret rotation.
philipat 11-14-2015 06:28 AM
Originally Posted by yellowshaker (Post 12126432)
will those work with HL or Taigen electronics? Do they come with a speaker box, or would I have to make that? (don't know what goes into a speaker box...)
yellowshaker 11-14-2015 11:22 AM
They will work with either as well as others systems. They do not come with enclosures. My stug has one without a box and it is very loud.
Sky_HawK 11-14-2015 01:59 PM
How's it sound with no enclosure? I planned on putting mine in a project box, mostly for ease of mounting.
philipat 11-14-2015 06:54 PM
Decent bass without the box?
